Customs MOTHER of LOWERING threads
Discussion in 'The Hokey Ass Message Board' started by The_Monster, Apr 20, 2014.
  1. The Bald One
    The Bald One
    Jag front with 2 cut coils, 4-link rear with camaro disk rear and bags, frame no notched. ImageUploadedByH.A.M.B.1398436963.484251.jpg
  2. Merc63
    Merc63
    4" cut from the coils in front, 3" blocks in the rear, raised the front shock mounts 1" to get travel back. Gonna do the same to my '63 Comet.
    Cooon likes this.
  3. fms427
    fms427
    OK- how much lowered ? A LOT ....No airbags - its always this low. We welded in the Camaro subframe and Olds wagon 4 link rear very high . it has full ride travel at this height - rides great ! All components are above the frame, so when it runs out of ground clearance it bottoms out the frame - wakes you up, but no damage.... Probably doesn't meet scrub line, tho .....:eek:
  4. J.P.
    J.P.
    from Michigan
  5. The_Monster
    The_Monster
    These are looking good!
  6. speaks
    speaks
    1. 4 door kustoms
    My 50 4 door has Fatman dropped uprights and steering arms, just under 2 coils cut and 3" blocks with a de-arched spring pack, 2 leaves removed and air shocks.[​IMG]
  7. The_Monster
    The_Monster
    Niiice!
    Anyone else want to show off their drop?
  8. cosmic12
    cosmic12
    4"s of block on the rear with CE springs. CE 2" dropped spindles and 2" raised lower control arms up front with stock springs with full travel and rear steer rack n pinion.
  9. Ratrod.piper
    Ratrod.piper
    from canada
    Mine has a fat man Mustang II suspension in the front I'm assuming it's dropped .not too sure by how much... Not too sure what was that to the back either but I kinda find the rear suspension flimsy
  10. slammed
    slammed
    [​IMG] 2" stepped A-arms+2" drop coils=5" settled into place up front. 2 full coils cut out of rear. Driven interstate no problem. Killer motors w/out OD cannot go far or long unless you putt-putt them for the trolls that know.
  11. 1964 Chevy C-10
    Front: Z'd the chassis (2" up, moved the cradle forward 1" to center the wheels), BelTech drop spindles (3.0" drop), 1 coil removed (2" drop), lower control arms moved 3/4" forward to gain caster. Wheels are 15x6 ET Super, tires are BFG 225/60-15.
    Rear: 1979 Chevy truck 12-bolt, factory posi, narrowed 3" total, Ford housing ends, Strange axles with c-clip eliminators, 5" drop coils, 2" lowering block, ECE Super Track Bar, ECE shock relocators, CPP C-notch, forward trailing arm brackets flipped for better angularity. Wheels are 15x8.5 (3.0 backspace) ET Super, tires are BFG 255/70-15.
    [​IMG][​IMG]
  12. mcnally351
    mcnally351
    from boston
    How many coils cut up front? On the shock mounts did you just shim the top of the mounts or a Shelby drop? Cool more door!!
    skin_dog1 likes this.
  13. The_Monster
    The_Monster
    yea, how many coils DID you cut to get that 4" drop??!! looks sweet!!
  14. B.Sharp
    B.Sharp
    my '37 GMC, fatman MII front end with 2" drop spindles. Aftermarket lowered short spring pack in rear with 3" blocks. '51 chevy 210 15" wheels with 205-75-15's. I like the thread. :D
  15. The_DropOut
    The_DropOut
    This thread is starting to take shape! What a great group of cars so far. They all look bad ass. Great to learn what it took to get them low.
  16. Last edited: Aug 31, 2014
  17. 40StudeDude
    40StudeDude
    Explain this comment, would you please slammed...???
    Might I suggest "killer motors" have been around a lot longer than OD has...and I used to drive my "killer motor' to the dragstrip and back home (35-40 miles one way) many times during the summer and it didn't have an overdrive...then downtown to 16th street every Friday and Saturday nite summer and winter...oh, it also had a 2:20 low 4-speed and a 5:13 rear end...!!!
    R-
  18. ynottayblock
    ynottayblock
    before (with 14" wheels):
    after (with 15" wheels)
    coil and a half out of the front, 2" blocks in the rear. Still rides like its on a cloud
  19. Cut 1 1/2 coils out of front (Aerostar springs too low), 2" blocks in the rear.
  20. The_Monster
    The_Monster
    oh yea! looking good!
  21. Gregg Pellicer
    Gregg Pellicer
    My 51 dropped upright's up front 2" block's in back stock spring's frt & rear[​IMG]
    cody ellingson likes this.
  22. srs1
    srs1
    S-10 front (had to be narrow) 78 Chevelle 4 link rear w/air. Body is channeled 2 inches[​IMG]
  23. Merc0Matic
    Merc0Matic
    from california
    hey I'm looking about using an air-over-leaf set up but i was thinking about using the firestone ride rite kits? anybody have any experience with those?
  24. toucan
    toucan
    from sc
  25. toucan
    toucan
    from sc
    areostar coils and 2.5 rear blocks.
  26. Merc0Matic
    Merc0Matic
    from california
    I already cut a coil out of the front and have 3 inch blocks in the back ImageUploadedByH.A.M.B.1401115418.944158.jpg
  27. oldrelics
    oldrelics
    from Calgary
    1 1/2 coils cut in front. 1 1/4" left before the bump stops.
    Rear, stock.
  28. The_Monster
    The_Monster
    hey! cool stuff! any more??!!
  29. VoodooTwin
    VoodooTwin
    from Noo Yawk
    2-inch lowering blocks in rear, 4-inch dropped axle (by Sid's Nostalgia) up front.
  30. 57countrysedan
    57countrysedan
    from NY
    ImageUploadedByH.A.M.B.1404178675.900356.jpg ImageUploadedByH.A.M.B.1404178696.960232.jpg areostar springs up feont and 2in blocks from butchs cool stuff. Think about 2 in all around. First pic i give credit toy girlfriend and instagram filters. As u can see from the second pic i dont have a eye for picture taking!
