I have a Mechanical It is a Moroso made by Jones Instrument Corp. Stamford CT. USA DL-367 I cant remember about The Cable that Came with it what it fits..?? or are the all the Same.? I called Moroso & they could not Help, and I called Jones & he just told it was a Old Tack what I knew already. Any Help with the Cable???? Just my 3.5 cents Live Learn & Die a Fool
2 choices.. Buy a vette tach cable... Or try and find an old school speedometer shop.. They can build it.. Sent from my SM-G973U using The H.A.M.B. mobile app
the end is larger than a normal tach, a Vette cable won't fit. look on ebay for Moroso Tach Cable, you should be able to find one. Make sure the other end has the correct shape to fit your distributor. Square and Tang are two common types.
Thank you Squirrel I'll check ebay, Thanks dave lewis also! Just my 3.5 cents Live Learn & Die a Fool
Fleetside66 that looks like the one I have only the one I have is 26" long which is too short. Thank You, Dom. Live Learn & Die a Fool
