Does anyone have the wiring diagram along with the firing order for the buick straight 8? I have the firing order, I need the diagram
You meant he wiring diagram for the wires from the cap to the plugs? If that is your question, then there really is no one answer since it depends on which post in the cap is set for #1. Pull the plug from cylinder 1 an slowly rotate the engine in the normal running direction. hen you feel it on the compression stroke continue to slowly turn it until the timing mark is aligned. Now check to see where you rotor is pointing. That is #1 on the cap. Now see which direction the rotor turns. Go to town with the firing order around the cap - that's all there is to it.
