Technical Mopar 8 3/4 used rear swap
Discussion in 'The Hokey Ass Message Board' started by zep058, May 30, 2014.
  1. zep058
    zep058
    So I've been wanting to change from my 2.76 highway gears for a while now and managed to pick up a complete axle with 3.23 gears cheapish.
    Had been sitting covered for a few years with oil in it (or should I say brown ooz).
    Overall it seems pretty good, no bad wear patterns or clunks etc. and wondering whether to give it a good clean and throw it in to my case and run it.
    What would you do and what are some checks I can do without a full tear down and rebuild which funds won't allow. Am I crazy thinking I can just bang an unknown rear in?!
    Thoughts?
  2. saltflats
    saltflats
    from Missouri
    I would clean it up and just turning it buy had you should be able to tell if it turns smooth or not if it truns smooth I would stab it in.
  3. 69fury
    69fury
    Agreed- if there's no signs of metal in the oil, then just clean it and chuck it in with new lube. They're pretty indestructable in a stock car, so i doubt it's got issues if you dont see any glitter in the oil.
  4. GTS225
    GTS225
    A; Is it a Sure-grip?
    B; If so, is it a clutch-type, or cone-type?
    C; If cone-type, check out the cones. They could be worn to the point of non-functional.
    Roger
  5. 49ratfink
    49ratfink
    I think you should ship it to me so I can get rid of my hiway gears in my 61 Dodge.
  6. saltflats
    saltflats
    from Missouri
    49ratfink what gears you looking for and for what housing?
  7. need louvers ?
    need louvers ?
    I too fall into the "just throw it in and run it group. Matter of fact, I did the exact same gig with my Plymouth about 100,000 miles ago. GTS 225 does bring up a good point though. If it is a cone type sure grip, those do wear to the point that the cones contact the out edges of the cases. I followed an article I Mopar Muscle from about ten years ago by Steve Dulcich on rebuilding then by machining the cones and re-shimming. It has worked very well ever since, so if you DO have problems, there is hope.
  8. zep058
    zep058
    So the "throw it in and run it" wins! I'm that way inclined just to give it a go.
    No metal and turns over by hand with no audible issues.
    I wish it was a sure grip! If I like this ratio I may throw a tru trac at it but for the moment just want to see what the gear change offers.
    I don't have another gasket but read to use a bit of rtv or sealant as an easy fix. Hopefully it seals it up no problem.
    Thanks for the advice gents
  9. 50dodge4x4
    50dodge4x4
    I haven't used a real gasket for a Mopar rear axle cover or center section since the mid 70s. Give the rtv time to set up before you fill it with gear lube and your good to go.
  10. 270dodge
    270dodge
    from Ohio
    So is it a 471-472 or a 489? If it is a 489 I can help (oh my, shipping !). Yes go for it.
  11. zep058
    zep058
  12. zep058
    zep058
    Yes 489.
    I wanted to show a video of the spider gears as they have some movement in them, not sure if the tolerance is okay
    Here a snapshot to show the gap, hope that makes sense
  13. zep058
    zep058
    try this
    Plung likes this.
  14. zep058
    zep058
    Last one then I'm done
    So from the videos, is that much movement acceptable? This is my first with a mopar rear end so not sure if it's okay to run.
    Thanks for listening!
  15. saltflats
    saltflats
    from Missouri
    The back lash on the pinion looks OK but the side gear movement dont look good.The carrier may be shot but you may be able to save it with some more shim behind the side gears.
    If you take the carrier out I would check the back lash with a dial indicator and make sure you set it up with the same reading.
    zep058 likes this.
  16. daliant
    daliant
    That's a lot of play on the spider gears, I would pull 'em out and shim them up nice and tight. Someone probably did a lot of peg-leg burnouts with that thing.
    zep058 likes this.
  17. Heads up.... The ring gear attachment bolts are left hand thread.... Ask me how I know.
  18. zep058
    zep058
    Thanks saltflats, it's starting to look like I should do this properly and get a rebuild kit and invest in a dial indicator. When you say set the backlash is that axle adjuster?
    Daliant, you are correct, evidenced by the bald tyre on the peg leg. Was hoping to just swap and go but may have to reconsider
  19. saltflats
    saltflats
    from Missouri
    The backlash is the clearance between the ring gear and the pinion. If I reuse a ring and pinion set I like to reset the backlash as it was you stand a better chance of not having a noisy gear.
    The adjuster behind the axle flange is for adjusting the axle bearing free play.
  20. daliant
    daliant
    Now's a good time to put a sure grip in it or one of those quick lockers that replace the spider gears on an open diff.
