mopar 340 fuel pump vs. hemi 241 difference
Discussion in 'The Hokey Ass Message Board' started by dodge59, Sep 2, 2013.
  1. dodge59
    dodge59
    is there any difference between a mopar 340 sb fuel pump vs a fuel pump for a hemi 241 redram ?
    mine has started to leak oil between the two halves on my 241 redram hemi .. I have two 340 Sb fuel pumps .......... just wondering if they interchange.
    Thanks !
  2. BashingTin
    BashingTin
    I don't think they do, but I think that TR Waters (Tom) here on the Hamb has a fix for this in the form of a spacer of some kind...
  3. George
    George
    Hot Heads also has a spacer, not sure if "73RR"(QEC) has them or not. Spaces the pump out about 1/2"
  4. 73RR
    73RR
    I quit selling spacers because they do not appear to work on 100% of the applications and I don't like 'those' phone calls.
    Once again...lay one of the pumps on the edge of your bench and trace the arm outline, note the sweet spot and the flange location. Now, do the same with the other pump and see if moving the LA pump away from the centerline will place the arm in a proper working location. If it looks like a spacer will work then buy one or make one.
    FWIW, Lately there have been numerous #4280 pumps on ebay.
  5. Kirk Hanning
    Kirk Hanning
    I've got a 53' 241" and acquired the spacer which would not work with any sbm pump. I ended up locating a stock style pump but they are pricy.
  6. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    What he said. ;)
  7. dodge59
    dodge59
    I ordered up a new remanufactured fuel pump.. $48.00 ..from rockauto .
    guess that isn't too bad a price.
  8. 73RR
    73RR
    Take the time to compare the two arms (new to old) as I have seen (and now own) several 4280 with not-quite-right lever arms.
  9. George
    George
    There's been a number of problems with wrong arms or pumps not working when bolted in. One buddy had a new pump that the arm would pop off the concentric.
  10. dodge59
    dodge59
    got the new pump from rockauto .. looks identicle to the old one ... installed it and it works great .. the original pump leaked oil between the two halves.. diaphram cracked . Now......... no more leaks .
  11. 64altereddart
    64altereddart
    from clovis ca
    I have heard a 318 pump works
  12. falcongeorge
    falcongeorge
    from BC
    318 and 340 pump are the same in terms of fitment.
  13. dodge59
    dodge59
    sb mopar 273-360 engines half inch longer than hemi 241. 1/2" spaced required
  14. good read....thanks all....
