Technical model t spring witch leaves do i leave out
Discussion in 'Traditional Hot Rods' started by 410merc, Mar 14, 2016.
  1. 410merc
    410merc
    hi every one yesterday was so nice so I rolled out my modal a tudor , and man does it set high , I have all the wood done so it has a little weight on it ,and of course when I swich and put the bowed one under it that will be a bit heavier ,but going to still be high so I have a model t ford rear spring , so heres my question what leafs sre the best to leave out , thanks a lot
  2. 410merc
    410merc
    I forgot to mention I am using a 9inch ford rerend and it will have a mild smallblock chevy
  3. Blue One
    Blue One
    from Alberta
    o_O Witch leaves :confused: Do witches have leaf springs on their brooms ? :D:D
    tfeverfred likes this.
  4. Ron Brown
    Ron Brown
    i left main leaf with reversed eye, 2 nd longest, cut off one inch from each end, 3rd longest then remove next , use next, remove all others and use A first leaf to center spring pack in spring pocket. i did a tech article on this see "Lowering My Model A" should help
  5. 410merc
    410merc
    thankyou for the reply , I don't think I can go that low ,because of the axle housing the 9inch ford is a lot bigger , so what leafs would be safe to leave out?
  6. cretin
    cretin
    Try every other one. Then you can add and remove to get desired height and ride quality. I don't know how finished your car is, but a finished car with full weight will obviously have an effect.
