Model T guys help
Discussion in 'The Hokey Ass Message Board' started by poofus1929, Nov 17, 2009.
  1. poofus1929
    poofus1929
    from So Cal
    I already did a search and came up blank. I am getting ready to build a frame for my 27 coupe and need some input on over-all frame length and wheel base length. Any body who has built one have any pics and numbers to help me out? I am building a 27 coupe with a small block chev. Can I use blue prints for a T-bucket chassis or will it be too small for a T Coupe?
  2. Boyd Who
    Boyd Who
  3. poofus1929
    poofus1929
    from So Cal
  4. Fenders
    Fenders
    A couple feet should do it.
    Duh.
    OK I was being a smartass. A friend has an early T telephone booth doctors coupe, with an SBC - stock wheelbase with hood. And not chopped !!
    The photo is somewhere in one of the HAMB threads.
  5. -Brent-
    -Brent-
    I really believe that this is something you're going to have to mock and measure. There are a lot of variables to consider. I just did some searching and the opinions varied. One guy mentioned three feet of space from the radiator to the firewall and another fit it in the stock location, these being in an A, however. That being said, the vehicle doesn't much matter if you're scratch-building a frame.
  6. poofus1929
    poofus1929
    from So Cal
    I wonder if I make it a few inches longer than an A frame K member to K member if it would be ok?
  7. -Brent-
    -Brent-
    I'm setting up a TT frame for my lakes/Indy-styled thirties cut-down T and what I'm planning to do is set the front suspension (ahead of the radiator) and then the radiator followed by front motor mount (I'm running a banger motor). After that I'm sticking to Model A specs as far as the frame and mount points and such.
    Now, I already have a frame, well, 3 frames actually that'll donate bits and pieces to become one. Overall, the wheelbase will be stretched about 4 inches. What I had to do to come up with the figure was crunch a lot of numbers, search and read, and continually measure and compare.
  8. chaddilac
    chaddilac
    I wouldn't guesstimate that's for sure... measure your engine, and body and frame. Go from there. You really only want to make the frame once!!:D
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Stock T wheelbase is 100". Many early hotrods with T bodies, even full-fendered use Model A frames with a wheelbase of 103 1/4" or in hiboy flair the 32 frame with wheelbase of 106".
  10. -Brent-
    -Brent-
    Stock T is actually 99.25" but it's possible to find them more or less than that.
  11. fiftyv8
    fiftyv8
    from CO & WA
    Set it up on a model A frame and work it out from there.
  12. rodrobb
    rodrobb
    from Sweden
    My T-coupe have 105" wheelbase. Its have a smallblock and a 700r4 trans
    and a 9" strange rearend
      120.3 KB
  13. poofus1929
    poofus1929
    from So Cal
    Nice looking car.
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I always say the shorter the better but if you get to Tweety Pie proportions then turn back and add 3 inches. This is my favorite T Coupe ever. I will own something very close to this soon er or later.
  15. poofus1929
    poofus1929
    from So Cal
    That car is sweet.
  16. J Man
    J Man
    from Angola, IN
    As far as wheelbase goes, it would depend on how you are setting up the frnt suspension as well. I would mock everything up and then take your measurements.
  17. steel rebel
    steel rebel
    Grabowski's T was reported to have a 96" wheelbase. Ivo told me his was 101. I think the difference was that Ivo used an early banjo diff. with the spring on top of the axle housings and Norm used the later one with the spring mounted behind them. Mine is 96" like Norm's.
  18. Fenders
    Fenders
  19. poofus1929
    poofus1929
    from So Cal
    I have a set of blueprints for a T-bucket frame. I wonder if they would work for a 27 coupe?
  20. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    As a rule of thumb I go with a Stock model t wheel base being a 100 inches.
  21. Track-T
    Track-T
  22. poofus1929
    poofus1929
    from So Cal
  23. fleetside66
    fleetside66
    Speedway sells T frames & chassis with motor mounts installed (& I would think they're for the sbc), so you might call them & ask what their measurements are & exactly where the mounts are placed in relation to the front & rear crossmembers.
  24. rallisracing
    rallisracing
    make sure you ask the wheel base on a prewelded T frame..Mine came in at 123" (yes 123)...I hope to be shortening it about 6-8" in the near future...
  25. OoltewahSpeedShop
    OoltewahSpeedShop
    My new little track roadster looks like it will be 102" but it will have a 261 Chevy 6-banger. I'm gonna need a little more room than a SBC powered car.
    Kevin
    Ooltewah Speed Shop
  26. poofus1929
    poofus1929
    from So Cal
    That is a long wheel base.
  27. Southfork
    Southfork
    Too many of the T's being built today have way to long a wheelbase in my opinion. I find those with a wheelbase of 106 inches or less most pleasing to look at, all things considered. Rodrobb's coupe (pictured above) looks just about perfect.
  28. poofus1929
    poofus1929
    from So Cal
    Agreed.
  29. Track-T
    Track-T
    Mines 108"...added 16" so the frame was closer to the body
  30. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Mine is 106" and I think it's perfect on somedays and 5 inches to long on other days. Depends on you taste. Royalshifters is 96" and that car is perfect.
    Here is my T with 106" WB...
