It depends on the wheels you intend to run, but in most cases the 46" after market axles usually are the best choice.
a guy brought the frame and some parts to our shop wants us to put the running gear together it will be full fendes with disk brake on the front so i better find out what wheels he will be running and see how low he wants it thanks
all the cars i have built been fender less he only brought on fender i gess i will find out more on monday after noon he talk to me 3 years ago about this he still have the stock model t frame but its been boxed i was told
well he got a 46 axle and a 4 inch drop he had drop arm for 1937 ford spindles he is running split model a wish bones the tie rod runs under the wish bones will that be ok this will be fun he put a sbc the exhaust is right next to the frame not much room and the frame is boxed
If you run the tie rod under the A wishbones it will be lower than the axle and you will see it from the front. Can you run it above the wishbones?
