Projects Model A with a hemi/A833od - shifter location?
Discussion in 'The Hokey Ass Message Board' started by El Jefe hemi, Sep 11, 2019.
  1. El Jefe hemi
    El Jefe hemi
    from BC Canada
    I am building a 30’ Ford roadster with a 354 hemi and am now deciding on a manual tranny. I am thinking of an 18 spline A833od from Passon? Looking for thoughts on how the shifter will sit in place and any other advice - pros/cons ?
  2. Oldioron
    Oldioron
    I wasn't aware of a 18 spline OD 833.
    To my knowledge, witch isn't saying much, the OD transmission is the weakest and the 18 spline the strongest.
    But there were two different tail shaft housings for the B/E body trans with two different shifter locations.
    Then you have the A/F body with a different length tail shaft but they are fine spined both OD and 1 to 1.
  3. El Jefe hemi
    El Jefe hemi
    from BC Canada
  4. Oldioron
    Oldioron
    I will see if I have the dementions
    stillrunners likes this.
  5. Oldioron
    Oldioron
  6. El Jefe hemi
    El Jefe hemi
    from BC Canada
    Thanks! That gives me a starting point.
  7. Desoto291Hemi
    Desoto291Hemi
    I think Passon made a 5 speed o.d. In the stock type case.
    It is very strong,,,,they added the extra gear in the tail housing area.
    Tommy
  8. el Scotto
    el Scotto
    from Tracy, CA
    It’s right underneath your right leg... lemme go see if I took a picture of a ‘31 coupe I built with an A833OD
  9. el Scotto
    el Scotto
    from Tracy, CA
    The dash and wheel didn’t stay long but here you go...
  10. dodgedifferent2
    dodgedifferent2
    I have the passon hemi overdrive a833 in my muscle car. I run 4.30 gears like I have 3.55 in 4th. I love the trans.
    I debated going with the t56 but would of had to do floor mods.
    Passons 5 speed A855 is a 5 speed trans but stand in a loooooong line to get one. The case is a bit bigger (longer) because of the extra 5th gear.
    I myself am currently working on a 30 coupe with 401 nailhead and the A/f body a833 trans (making my own adapters) I have also been looking at the shifter and scratching my head.
    El Scotto were you worried about bending the shifter with extreme shifting?
  11. Don't forget the trucks and vans ! Bothe 6cyl and 8cyl versions....last one I pulled came out of a van at picknpull.
