Model A steering column question
Discussion in 'The Hokey Ass Message Board' started by Nick O, Oct 5, 2010.
  1. Nick O
    Nick O
    from Ohio
    I have a 30 Model A Closed Cab Pick up that I am building and I have a steering column question that I hope I can get some help on. The car is on standard A frame rails, SBC, vega box, stock firewall with distributor recess and bench seat in cab. I would like to run a 40's style wheel and my question is what lenghth of column, mfg and style do you think will fit best. Should i go with tilt do to the space limitations in the closed cab pu? Thanks for your help.
  2. squirrel
    Make your own column, it's just a tube with a bearing at each end. Tilt will look quite out of place with a 40s wheel, won't it?
  3. F&J
    F&J
    If making a column sounds too hard for you...
    Try to get the whole column from the car with the wheel you want. It will have a steering box attached, but you just cut it off to your length, and then get a lower bearing for it, as well as a ujoint.
    If you find the column, there will be people to help get you going, if you get stuck.
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    In my opinion it would look out of place too
  5. terry48435
    terry48435
    Speedway sells a cheap column in different lengths with a removable wheel setup like a racecar,Makes it easy getting in and out. It's about $100.
  6. 35mastr
    35mastr
    from Norcal
    Contact Limeworks here on the Hamb. He is an Alilence vendor. We just got one for a 34 coupe from him with a 40 wheel. Steve will take care of you. Very nice product.
  7. If you can score a 60s era tilt somewhere (they tend to run around $150 a shot) it will look reasonable with an early wheel on it. With the GM box I'd just use a GM column of some sort, since the splines will match and you can put most any GM wheel on them.
