Model A Sport Coupe Project for the wife
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Apr 10, 2010.
  1. HomemadeHardtop57
    HomemadeHardtop57
    por 15 on the inside ..shitty cell phone pic
    Got the engine degreased, primed and painted..thanks Koz for the paint. This color should look nice against what I have planned for the body. Couldn't help laying the intake and valve covers on. Had no place for the painted engine in the shop so I just stuck it back in for the moment
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    What color is that on the motor??? I originally planned on my 265 being painted a color similar but ended up going up with black. That looks killer!
  3. HomemadeHardtop57
    HomemadeHardtop57
    It's called "waste management maroon" ....seriously...hahaha.....and is a fleet industrial vehicle color. I used a single stage paint with hardener and sprayed it with a gun. Koz used it on his roadster pickup a couple years back and had some left over. It's close to 40 Ford Mayfair Maroon
  4. JeffreyJames
    JeffreyJames
    from SUGAR CITY
  5. Wow Jerry, I totally missed this thread and had no idea you were building this. It looks freaking awesome. You and your wife should be proud. Remember I have that louvered visor if you want it. Let me know and I'll bring it out to you.
    And people call you a music teacher!
  6. HomemadeHardtop57
    HomemadeHardtop57
    Hey there, thanks for the compliment..been working on it all summer. Hope to see you soon.
  7. HomemadeHardtop57
    HomemadeHardtop57
    Back at it tonight. Got the water pump painted and installed. I forgot to paint it the other day when doing the engine. Ordered the crank and water pump pulleys too...should be here Friday. I got chrome ones..but don't want it to look gold chainer so I might paint them black when they come..not sure yet.
    I decided to go with an older pair of rams horn manifolds instead of the lake headers. I think these will suit the car better. Cleaned them up and painted them along with the generator bracket. Starting painting the generator tonight too...Need to get some more bolts for exhaust manifolds..ran out
  8. No one will call you a chainer with chrome pulleys. You could always have a little late 50s early 60s vibe going on.
  9. 41 Dave
    41 Dave
    Jerry, That SBC is looking very sharp ! Love the industrial Maroon and the polished aluminum. Very nice combo. Agree about you choice of the ram horns over Lake Headers. It is very clean, simple and will be easy to take care of.
  10. HomemadeHardtop57
    HomemadeHardtop57
    Still waiting on some parts for the motor..the shop ordered the wrong damn pulleys.
    I made a decklid skin tonight. Bent up a flat sheet of steel to specs and went to town with my shrinker machine. After a while I had a nice new skin. Sprayed my generator and some brackets with a single stage jet black enamel that looks killer. It's a factory Harley Davidson paint that my friend Don had left over from a paint job. Here's some shots of the new skin
    Yanking the motor back out and the body off Monday so I can prime and paint the frame and suspension.
  11. thunderbirdesq
    thunderbirdesq
    Attaboy Jerry! I like those ramhorns on there.
  12. 35mastr
    35mastr
    from Norcal
    Motor looks great. Nice job on the decklid.
  13. HomemadeHardtop57
    HomemadeHardtop57
    Got the motor just about finished. Have to install the distributor and plug wires and it will be all ready to fire. My pulleys finally came in and I put them on along with a fan,spark plugs, generator,and oil fill tube.
    Couldn't yank the body off because I had to go with an F-1 box instead of my 40 Ford. This was necessary because of the change in exhaust manifolds and the steering box mounting location. Took longer then expected to find a decent F-1 setup..but a good friend came through with a nice one. Have to get it mounted up this week...and then I can paint the frame.
    Scored a nice set of 50 Ford trunk hinges from 1oldrat which I started to put on tonight. I think they look neat. Got the holes in the body drilled..need to do the decklid holes.
    Stogy likes this.
  14. rocknrollratfink
    rocknrollratfink
    from LA
    You have mad skills!
  15. HomemadeHardtop57
    HomemadeHardtop57
    With some help from my buddy Eli..I should have the steering all done by the end of the week..then the body comes off finally for the last time...more pics soon
  16. HomemadeHardtop57
    HomemadeHardtop57
    took a break from this the past couple weeks....but got back on it again.
    got help putting the steering in so she now turns...My Speedway order came in so I installed the drag links and the new tie rods...heated and tweaked the pitman arm a little. Got the firewall boxed and clearanced for the distributor. Flattened the upper portion of the lower firewall to make boxing easier...just some finish welding on the firewall to do when the body is off. Should look seamless when welded and blended.. ...inside floor finished completely.
    fan shortened and installed..needs paint..
    reverse eye main leaf installed in the rear...took a couple leafs out of the front too. Once I get the right tires and wheels on it should sit just right..
    Time to yank the body off!!! Finally
  17. Pat Pryor
    Pat Pryor
  18. 41 Dave
    41 Dave
    Jerry, You are making some excellent progress ! Like the look of the manifolds. Simple is usually more of a statement. Looking forward to further updates.
  19. HomemadeHardtop57
    HomemadeHardtop57
    Started ripping her apart today for paint!
  20. lorodz
    lorodz
    how can i get a pair of them punched aprons ....without the rod end hole in them ...?? let me know
  21. Hot Rod Michelle
    Hot Rod Michelle
  22. HomemadeHardtop57
    HomemadeHardtop57
    Update.
    Body is off the frame and that hogged up quarter is getting some metalwork attention from my friend Koz. I was going to just bang it out and mud it up..but I just couldn't get myself to do something half assed like that. It needs to be right.
    Afterwards we are going to make a removable top from aluminum which I will have upholstered later. I was going to go the fiberglass top route like Clark did..but I think I can make one faster and cheaper from metal.
    Looks like it's going to be 41 Ford Niles Green with black suspension and maroon wheels ( to match the motor) with wide whites on 16 in 40 Ford steelies
    The Niles green is a really light blue-green with no metallic. Interior will be maroon and the dash will be Niles with a maroon wheel and column.
    Currently, the frame and suspension is torn down and I'm prepping everything for prime and paint. I'd like to be able to take this thing for a spin before it starts snowing....damn east coast!!
  23. HomemadeHardtop57
    HomemadeHardtop57
    Started laying down some color on the wheels in my downdraft booth..haha ..got them primed this morning and shot the maroon on them this afternoon.
    Also primered the side aprons
  24. Oooh, that maroon is nice!
  25. Clark
    Clark
    Can't wait to see the colors come together.
    Clark
  26. That is a bitchenmaroon!
  27. 35mastr
    35mastr
    from Norcal
    Color looks nice. Cant wait to see bigger panels painted to see what it really looks like.
  28. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I should send you something to squirt that paint your using on the next type you spray so I can color match it here. It looks awesome!!!
  29. HomemadeHardtop57
    HomemadeHardtop57
    Back at it again tonight. Wheels are dry..came out really nice. Grounded down some welds on the frame ...wiped it down and gave it a couple heavy coats of primer.
    Went up to Koz's tonight to help work on the quarter...it's coming along nicely....he's fabbing up some nice patches for the beltline
  30. HomemadeHardtop57
    HomemadeHardtop57
    My dad was sick..so I took the past couple of days off..but I made some progress.
    Got the frame, front and rear suspension primed and painted. I wasnt happy with how the paint place mixed the color for the frame..so I added some black and got it just right.
    When things were dry I hung the front end suspension.
