Model a sedan, how to lower it
Discussion in 'The Hokey Ass Message Board' started by 64ONEOFF, Nov 30, 2012.
  1. 64ONEOFF
    64ONEOFF
    from Md.
    Hi, Fellas, I am eventually gonna buy or build a frame and drop axel(SAVING FUNDS). I was just wondering is there a CHEAP way to lower the car for now without spending a ton of $. It still has the 4 banger and I am having a blast, But sits way to high. If anyone knows a backyard bang for your buck way, I would really apprieciate it.... Thanks Jeff:D
  2. flatout51
    flatout51
    Reverse the eyes on the front spring and flatten the front crossmember... Get a Model T rear spring for the back.
  3. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Let the Air out of the Tires.
    (I just couldn't resist).
    VR&C.
  4. 64ONEOFF
    64ONEOFF
    from Md.
    VOODOO, Thats F#$%!@ up, But funny as hell:D
  5. Derek Mitchell
    Derek Mitchell
  6. need louvers ?
    need louvers ?
    flatout51 said it best, but also de-arch the front spring a bit.
  7. Carter
    Carter
    Depends how low you want to go. Quick and easy would be to reverse eye the front spring, put at spring in rear. Next you could do a 32 or 33-6 axle up front and reverse eyes on t spring out back.
    After that would require z'ing frame in rear or some other type of frame modification.
    Sent from my DROID device using the TJJ mobile app
  8. manyolcars
    manyolcars
    The word you almost got right is DROPPED axle
  9. A Rodder
    A Rodder
    I used a dropped axle up front but to get the rear down, I used a T spring which seems to go for 80 to 125 bucks and cut the top of the rear of the crossmember out and "re arched" it two inches higher which in the end netted me probably a solid four + inches of drop.
    Also if you can get some taller tires on the rear, it won't lower it any but will help fill that wheel well area where the fender bolted on. Looks a little better.
    The modification to the rear is in my thread in my signature line.
  10. 64ONEOFF
    64ONEOFF
    from Md.
    If anyone could explain with a little more detail about flattening the cross member, I would apprieiate it....Thanks
  11. A Rodder
    A Rodder
    It dips downward from the sides towards the center. When you flatten it you raise the center to match the sides. So it is on a same horizontal plane all the way across the crossmember.
    In effect, raising the height of the spring, thus lowering the chassis.
    Does that make sense?
  12. 64ONEOFF
    64ONEOFF
    from Md.
    Yes sir, thanks for your time.
  13. Ford Blue
    Ford Blue
    Good info, Thanks
  14. GZ
    GZ
    from Detroit
    Here's a 1929 Tudor I just lowered. It has an 8 leaf rear Model T spring and stock rear crossmember. The front spring is a 8 leaf SoCal Speedshop reversed eye spring that has a lower arch than the stock A spring. The front axle is stock as is the crossmember. The wheels are 16" with 7.50 rear tires and 6.00 front tires.
    The 1928 roadster has the same treatment.
  15. choppedtudor
    choppedtudor
    well, I went overboard and a bit unorthadox, with a 7 1/4" chop, a 4" channel AND a double-z frame....but then I tend to take everything to the limit. My avatar was before dropping the frame...
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    dropped axle, reverse eye springs, maybe take a few leafs out of the front and rear springs..shit like that
  17. 64ONEOFF
    64ONEOFF
    from Md.
    Choppedtudor, looks like we are starting with the exact same car. I like to see your pics of the body on the z'd frame. Good luck
  18. You can't install longer shackles on a Model A
  19. 64ONEOFF
    64ONEOFF
    from Md.
    Hitchhiker, I was looking at that last night. You are correct. I am not seeing a way to extend shackles.
  20. LSR 2909
    LSR 2909
    from Colorado
    Is the rear spring a stock Model T?
  21. GZ
    GZ
    from Detroit
    Yes, the rear spring is a stock, 8 leaf Model T rear spring, no modifications.
