Technical Model A seats
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Oct 9, 2019.
  1. Dino 64
    Dino 64
    from Virginia
    ok, I know there have been other threads on this but since my HAMB app crapped out on me, I can’t find the thread. I found a 2014 Caravan middle seat. Seller measured for me, 40” wide on the bottom cushion widest part. Is this the one that will fit. I seem to remember that was the magic number. It folds down too. Can anyone confirm this for me ?
    Thanks guys
    Just Gary likes this.
  2. I believe you're looking for 3rd gen Dodge Caravan middle seat. Folds forward.
    patmanta and Dino 64 like this.
  3. catdad49
    catdad49
    Dino, that's what I have. If you mount it low you will have to remove the plastic end covers and flatten the seat back adjusting handle because of the body taper.
    Dino 64 likes this.
  4. Dino 64
    Dino 64
    from Virginia
    Thanks, going to look at it tomorrow, only a 3” chop on mine so I don’t think I’ll have to mount it too low.
    lothiandon1940 and Just Gary like this.
  5. Dino 64
    Dino 64
    from Virginia
  6. GordonC
    GordonC
    I have the 3rd seat from a caravan and had to take 6 inches out of the middle of it to get it to fit my A roadster. That is with all the stock trim and handles in place I think the one to use is the middle one. . Just put it in this afternoon! Here is a pic.
  7. Dino 64
    Dino 64
    from Virginia
    Looks great !! How wide is it ?
    lothiandon1940 likes this.
  8. catdad49
    catdad49
    Dino, the seat is 40", but the covers on the sides increase it to approx. 42". The position front and back and up and down will have an effect on whether or not you can use the seat without alteration. There are a lot of variables that will determine the optimal seat postion and If it is non adjustable the problem is compounded.
    Dino 64 likes this.
  9. Dino 64
    Dino 64
    from Virginia
    Thanks, that’s my concern. I bought one about a year ago and it seemed too big so I’m in the fence about it, Thanks
  10. catdad49
    catdad49
    If you're really doubtful about it, narrow it 2". At that width there should be no problem where it's mounted. I would like to lower mine about an 1 1/2", but it may not work because of the body taper. It is really comfortable so I may think on it for quite a while! IMG_1991.JPG
  11. Dino 64
    Dino 64
    from Virginia
    Thanks, did you chop your coupe, one of the variables. I figure with a 4” chop, it would be in the floor, mine is chopped 3” so I should measure the body height at one inch up.I have no idea how to narrow the seat,:(:rolleyes:
  12. catdad49
    catdad49
    Dino, no chop. I have plenty of head room, but I would like to sit a little lower (we'll see). Do you have a welder?
    Dino 64 likes this.
  13. Dino 64
    Dino 64
    from Virginia
    Yup, just spent some time measuring. With the 3” chop I’m sitting about 6 1/2”above the floor. Can you take the “legs” off ? I bet the cushion itself is about 6” high in front. Seems like it will be really close. I put the doors on and measured across at the approx height of the cushion and got about 42” maybe a little less.
    Still on the fence, :rolleyes:
  14. Dino 64
    Dino 64
    from Virginia
    Yes I have a welder
  15. GordonC
    GordonC
    I don't recall the length of it but do know I got it from the 3rd row in the caravan. I can measure it if that is important? I cut the middle of it. Three inches either side of the center of the seat. Then I used the stock cover as a pattern for the tuck and roll I did. I also used the stock seat brackets and cut and welded them to a 1 x 1 inch tube frame I made which bolts to the floor of the car. It's finally all coming together. The only thing left is to carpet the firewall area.
    Dino 64, akoutlaw and Texas Webb like this.
  16. Dino 64
    Dino 64
    from Virginia
    Thanks it came out really nice :)
  17. catdad49
    catdad49
    Hey, Gordon! The rear seat is 46", ask me how I know. Dino, follow Gordon's advice, but remove 2" inches instead of his 6". Remove the seat covers (go slow so you don't tear up the foam) and remove the 2" as you did with the seat frame. Then on to upholstery! The seat for my Coupe was my wife's first, I think it turned out Great and it sure is comfy.
    GordonC and Dino 64 like this.
  18. Dino 64
    Dino 64
    from Virginia
    So I’ll have to reupholster it ? I assume the foam will be cut as well to make up for the 2” ?
    Thanks, plan on looking at it later today
  19. catdad49
    catdad49
    Yes on the upholstery. I think you use the same procedure with the original covers, but I'm not a seamstress.
  20. Dino 64
    Dino 64
    from Virginia
    Thanks, appreciate it;)
  21. GordonC
    GordonC
    Yes just take the same amount out of the foam as you do from the seat and then glue it back together. Same thing with the cover. Catdad49 your seat came out great for a first time effort!
    Dino 64 likes this.
  22. catdad49
    catdad49
    Thanks, Gordon. My wife does Great work, probably even better without My help!
  23. Dino 64
    Dino 64
    from Virginia
    Thanks guy appreciate the help:)
    catdad49 likes this.
  24. I did the shifter for my Ford T-5 in my '58 F-100 just about the same. Under the seat and all.
    GordonC, Dino 64 and catdad49 like this.
  25. catdad49
    catdad49
    Tim, if my legs were just a little bit longer, I could move the seat and use a regular shift handle! As it is it works fine, how about some more pics of your truck?
    Dino 64 likes this.
  26. Dino 64
    Dino 64
    from Virginia
    6E2F7606-3135-42DB-B6B1-4107EAF8FDE7.jpeg I have. T-5 but with a tail shaft that pushes the shifter forward, almost to a stock position
    akoutlaw, mcsfabrication and GordonC like this.
  27. GordonC
    GordonC
    That exhaust system isn't going to rattle or move around at all! :D
    catdad49 and Dino 64 like this.
  28. GordonC
    GordonC
    Catdad49 you could always put some wooden blocks on the pedals! :D
  29. Dino 64
    Dino 64
    from Virginia
    4895D741-A024-4480-8483-882512ABF963.jpeg I guess I over did it;)
    I went overboard on the brake and fuel lines too:eek::D
    GordonC and catdad49 like this.
  30. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Depends on how much effort you want to put into it. I stripped my Caravan 2nd seat down to bare frame, cut off all the mounting brackets, made my own with 1/4" strap and a universal seat mount from Jegs. A lot of time was spent getting it as low as possible and at the right seating angle so it's comfortable (more than a lot of modern cars!). The dreaded non-traditional slide out cup holder is still functional and comes in real handy. My seat back doesn't fold forward unfortunately.
