Besides the r wood and fabric what is a cool alternative way to put a roof on a 29 truck cab? Posted using the Full Custom H.A.M.B. App!
Full sheet steel homemade roof not that hard and not too big to be a problem. I used an early Granada roof turned sideways. You will need to roll your own side edgings and weld a panel in between the edges, wooden back upper panel will need to be replicated in metal. The first 3 pic's are of somebody elses project I saw on the internet, could have even been the HAMB. The last pic is my roof not completed yet. You can also use 26/27 model T coupe or tudor steel latch pillars in your pickup in place of the original wooden pillars... http://www.jalopyjournal.com/forum/showthread.php?t=438263
To add to that you might even make some patterns out of cardboard that are cut out with what should be the original curvature of the roof you are trying to replace to be able to find a roof with a matching shape. That may make for a bit less metal work when you install it.
No, simply put,laid 3/8" plywood in the groove around the top then laid another 3/8" plywood covered with material on top of the first piece.. The top is held with bolts that were put in the top before the material went on...
I used the back end of the main roof, including part of the bend where it went down to the rear window. I had them cut it too big at the junkyard, then fit it back at the garage ( you can still see the center line) I took a picture of the side view of the coupe and walked around comparing rooflines till something looked close, and this one slid in like it was made for it. The year I posted may not be exact- this was about 10 years ago- but it was definitely a full size Buick.-------- I did a roof for a Tudor with a Chevy conversion van roof- the van roof turned 180* fit perfect ( front of the van roof on the back of the Tudor roof). I liked it because it had ribs that went UP instead of "troughs". I cut the ends off the salvage piece and finished the front with them, so the rib ran full length and had finished ends front and back.--- I have another coupe now and I'm thinking of an insert like "scrapmetal48" did- looks mighty fine!
I made my own top wood as this '29 has been stretched 6-1/2" and then treated it like a padded top. The profile is considerably flat as compared to a stock roof
"Gas Tires Oil"--Thanks for the compliments- I lucked out, but I did do some Research and Development too! Hope it helps someone else get closer to their project coming together. Drive safe and have a great summer. Mike........BTW- love the Sonny Barger "signature" statement; sounds about perfect to me!
