Technical Model a roadster question
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Apr 10, 2023.
  1. oliver westlund
    oliver westlund
    Working on a buddies 30/31, need a pic of what the sub stanchions bolt to. Can we buy this piece? And where? The piece that goes behind these Screenshot_20230410-210701_Chrome.jpg
  2. oliver westlund
    oliver westlund
    As you can see, on his body they were torched off Screenshot_20230410_212914.jpg
  3. Joe Blow
    Joe Blow
  4. oliver westlund
    oliver westlund
  5. Joe Blow
    Joe Blow
    Grabbed the wrong one.
    warbird1 and oliver westlund like this.
  6. oliver westlund
    oliver westlund
    Joe Blow likes this.
  7. Joe Blow
    Joe Blow
    You may want to look for a donor car.....that's more than likely what happened to your bud's car....when someone got a load of what repops cost.
    oliver westlund likes this.
  8. The37Kid
    The37Kid
    Henry originals on my '30 Roadster. You can see that the riveting is a bit complicated and the top door hinge mounts between them. I would think Brookville has them.
    oliver westlund and Just Gary like this.
  9. oliver westlund
    oliver westlund
  10. oliver westlund
    oliver westlund
    I think most of it is still in the car, i might just fabricate whats missing
    The37Kid and Joe Blow like this.
  11. Budget36
    Budget36
    Maybe @sloppy jalopies has them? Sure seems to come across a lot of A stuff.
  12. The37Kid
    The37Kid
    You will be welding to a forged original piece, a lot of things have to align perfectly so the post look right and everything is correct and strong at highway speeds hitting a flat windshield. A junk cowl with good pieces swap may be the better way to go.
  13. oliver westlund
    oliver westlund
    I imagine to fabricate it, id have to bolt my pieces to the sub stanchions then assemble the entire setup with a ws frame to make sure its all square, tack it, pull it apart and finish weld it
    Algoma56 likes this.
  14. The37Kid
    The37Kid
    That is the easy view. The lower station, gas tank, cowl panel, and under windshield piece, and door, all meet in that area. If you like equal gaps around everything there is a bunch of fitting, adjusting shimming and welding going on. Get the windshield fit first then fine tune the rest.:)
    Algoma56 and oliver westlund like this.
  15. sloppy jalopies
    sloppy jalopies
    got nuthin...
    but a buddy just picked up a reasonable '30 cowl may be for sale ?
    p m... me if you are near enough to 04210 for "you pick up" to make sense...
    get you his phone # ...smitty
