Technical Model A Rear spring spreader
Discussion in 'The Hokey Ass Message Board' started by gbgh, Aug 20, 2017.
  1. gbgh
    gbgh
    I have access to a rear spring spreader that works great on conventional buggy springs but not so well on reversed eye units. Any tips on how to do this safely greatly appreciated! Standing by with the ever popular 2x4 and grease method.
  2. bct
    bct
    not my equipment or even my picture ,
    catdad49, Texas Webb and Frank Carey like this.
  3. Ya, I've seen all that Trick stuff. Problem has been that the Diff center housing is often the next problem. For me I just take the spring apart, install the main leaf by itself (by hand) then with a piece of all thread put the spring pack back together. With 2 C clamps remove the all thread and replace the center bolt. Yes, it can still be a job depending on spring over or behind the Axle Housing but to date I've never had a spring get away from me.
    The Wizzard
    catdad49, Moriarity, AVater and 2 others like this.
  4. gbgh
    gbgh
  5. gbgh
    gbgh
    But it works for Me!!
    Thanks!
    bct likes this.
  6. Sweet & Low
    Sweet & Low
    Necessity if the mother of invention as the old saying goes. I thinks it's a very cool idea for reversed spring eye's. No reason it wouldn't work either way.
  7. Bbhf
    Bbhf
    from Ct
    I agree with Pist-n-Broke: Whether taking them apart or putting back together, the c clamps and all thread rod works every time: Make sure your clamps are up for the job: Also make sure you use the right diameter threaded rod with two nuts and flat washers on each side to help take the load: Take your time: sk
    AVater likes this.
  8. AVater
    AVater
    1. Connecticut HAMB'ers
    Did what the Wizard and Bbhf said. Works fine.
  9. I'll add this little piece of info for ya. Years ago I learned if I use a bearing from a Ford King pin set and a extra heavy washer (generally a plug cut from a 1/4" plate with a 1-1/4" hole saw) turning the nut on the all thread is a walk in the park. I double nut and jamb the short end of the all thread.
    The Wizzard
    AVater likes this.
