What is the best seat to use for a model a pickup seat? I'm thinking about using a third seat out of a chevy station wagon. Anybody done this?
I dont know what the best way is , but here is what I am using. It is a school bus seat. Not only does it fit , but the frame is sturdy and should add some strength to that 75 year old cab. I am removing the wood from the back of the cab and using the seat frame in its place. Space is at a premium so every inch and fraction of an inch is a bonus
I used a mid 90s Dodge mini van middle seat, took off the headrests and bolted it to the A model seat frame. Works great.
This might help......... saved this from here on the HAMB '87-'89 Ford Escort rear seat Seat back width = 42" Seat bottom width = 42" Seat back thickness = 3.5" (seat back folds forward) '90 Dodge Caravan, middle seat? Seat back width = 44.5" Seat bottom width = 44.5" Seat back thickness = 4.5" '80s Isuzu Trooper Seat back width = 48" Seat bottom width = 48" Seat back thickness = 3.5" '84 Ford Ranger Seat back width = 49" Seat bottom width = 49" Seat back thickness = 3.5" '84 Toyota van middle seat Seat back width = 34" Seat bottom width = 36" Seat back thickness = 4.5" '91 Ford Festiva Seat back width = 38" Seat bottom width = 48" (odd shape is fitted to wheel wells) Seat back thickness = 3.5" '89 Ford Aerostar middle seat Seat back width = 39" Seat bottom width = 46" (odd shape) Seat back thickness = 4.5" '91 Chevy S10 pickup bench seat Seat back width = 48" Seat back width = 5.5" Seat bottom width = 49.75" Seat bottom thickness = 6" The seat would bolt to a flat floor, with the frame the bottom cushon at highest point looks to be 9.5" high. Bottom cushon has two holes for seatbelts to pass through. OK - Wrangler stuff (pretty small - maybe good for Model A) Seat Back Width - 32.5" Seat Back Height - 15.5" (from hinge) Seat Back Thickness - 5" Seat Bottom Width - 33.5" Seat Bottom Thickness - 5" (at bolster) Seat Bottom Depth - 15.5" (front to back) Found one that mounts to the floor in a severely channeled 26-27 T ....90's Isuzu Amigo back seat. SEAT BACK 39"x21"x3" SEAT BOTTOM 39"x20.5"x8" Seat folds forward and the "folded seat" folds forward again! 85-6 Dodge Colt Vista van rear (3rd) seat. 38 inches wide-21 inches deep. integral retractable belts (center) earlier ones don't have headrests thin cushions and backrests I used modified 80's Chev PU seat tracks on this one splitback reclines and folds on cushion
