Projects Model A pickup, my first build thread
Discussion in 'Traditional Hot Rods' started by F-6Garagerat, Sep 11, 2010.
  1. mista
    mista
    from Finland
    Like a glove..
    brEad, 120mm, bryanyeskie and 3 others like this.
  2. Schwanke Engines
    Schwanke Engines
    I would have strapped that flywheel in the lathe and put it on a 20lb diet.
    Sent from my XT1585 using The H.A.M.B. mobile app
    Runnin shine likes this.
  3. Schwanke Engines
    Schwanke Engines
    But, that's just me we usually get 12-15 lbs off the stocker model a flywheels.
  4. mista
    mista
    from Finland
    Maybe in the future that will happen. My main concern is to get all the parts i need and get the car running before summer to get it registrated. Next winter some bigger upgrades.
    I guess i should raise the front end of the engine a littlebit to get the waterlines from the waterpumps to fit to the radiator. I guess these rubbermounts on my car are stock size..? Then i have to check will the stock oil breather fit so that it wont hit firewall.
  5. bengeltiger
    bengeltiger
    Engine looks good in your frame. Well done!
  6. mista
    mista
    from Finland
    Any suggestions on a radiator? Would have to fit to the 32 grille and have all the hose connections for flatty v8.. I know you all will say go with the Walker but its just i would not like to spend 800 bucks on a radiator.. Are those ebay radiators any good?
    I had this one but it won't fit. I guess it 33-34?
    I also fired the engine for the first time yesterday.. Sounded loud without exhaust :)
  7. Superior Radiator will make whatever you want, for about half the price of the Walker. Just tell them what radiator shell and engine you'll be using.
    http://www.wwwsuperiorradiator.com/
  8. Never2low
    Never2low
  9. mista
    mista
    from Finland
    Thanks guys. I sent emails to both companies.
  10. mista
    mista
    from Finland
    I hope the cab is on tomorrow.
    Mikel50 and AndersF like this.
  11. When I ordered mine, I also told them how far below the top of the frame rails to put the lower water inlets, so they lined up with the Flattie's outlets. They were spot on.
  12. fastmike
    fastmike
    from Mesa AZ
    I got my aluminum radiator from Gearhead enterprises. They sell them on fleabay for $150. I haven't installed it yet so I cant tell you how it holds up but it does look very well built.
  13. mista
    mista
    from Finland
    Got the cab back on and started to try how would the lakes style headers look like.
    Kevs56 likes this.
  14. safari-wagon
    safari-wagon
    Very cool, dude!
  15. Mikel50
    Mikel50
  16. oldgoat939
    oldgoat939
    I have a 29pick-up (the one in my avitar) and the wife and I are driving across Canada from B.C. to Newfound Land and then back thru the U.S.A. following the old route 66. We are both under 5 foot 8 inches and the top is stock height and it is really nice to drive and we pull a canned ham trailer and have had no problems yet, so build the truck the way you want and drive the wheels off it when it is done.
    Jet96, jnaki and mista like this.
  17. mista
    mista
    from Finland
    Small progress
    brEad, Jet96, OFT and 1 other person like this.
  18. mista
    mista
    from Finland
    Nothing huge again..
    OFT likes this.
  19. mista
    mista
    from Finland
    The other side is still in progress..
    OFT likes this.
  20. fastmike
    fastmike
    from Mesa AZ
    Looking good man!
  21. mista
    mista
    from Finland
    Testing a hood with cardboard..
    ct1932ford, rjones35, brEad and 2 others like this.
  22. OFT
    OFT
    Nice looking profile!! Shovel-head with springer looks good too. Does it have a pan-head bottom?
  23. knotttty
    knotttty
    It's a sportster ... just saying ...
    Sent from my SM-T560NU using The H.A.M.B. mobile app
  24. mista
    mista
    from Finland
    Yeah it's an Ironhead from 1975. You can see another one in the back of the car. From 1974.
    I wreally need to redesign the clutch levers on this thing.. My leg starts to shake every time i step on the clutch. Stiff as hell. And since the cab of the pickup is small and i'm quite tall it does feel very shitty to press the clutch pedal right now.. Won't be anything to enjoy about riding this thing if it will stay like that..
    knotttty likes this.
  25. mista
    mista
    from Finland
    If i understand right the clutch leverage goes like this?
    Also the headers are done now..
    brEad likes this.
  26. OFT
    OFT
    Looking real good!
    Your drawing looks good. Longer leverage gives easier pedal effort.
  27. mista
    mista
    from Finland
    First start..
    waxhead likes this.
  28. OFT
    OFT
    Sounds great! !!
  29. mista
    mista
    from Finland
    Hi guys.. A small problem that might have a big solution.
    I don't have any oil pressure. I've been reading all the threads about this issue and trying some basic stuff..
    I tried that the electric gauge works by blowing compressed air to it. It works. I tried pouring some oil to the hole behind the block that the gauge is installed to and started few times for a while without plugs.. Nothing. Is there anything to do besides taking the oilpan off and checking the pump? There is no leaks in front or the back of the engine so i assume the plugs to the oil galley are in.
    Is there something i can check from the breather hole before taking this shit apart?
    Help would be much appreciated.
  30. mista
    mista
    from Finland
    I took the oilpan off and took the oilpump apart. Cleaned everything and assembled with the 80w90 inside. Still no pressure on the gauge. Mechanical gauge tested with compressed air.
    Last thing i did i took the gauge off from the block and started few times and tthe oil is pouring from the hole quite well. It did not shoot to the roof but flooding from the hole. So i guess there is at least something. If not pressure but at least flow.
    What do you guys think?
