I have this model T chassis lying around at home and am planning to build a 1910 era race car with model A running gear. Now doing a little chassis mock up I was wondering if mo model A leafspring shackles fit the the model T springs? Still am searching for T front and rear leafsprings. Anybody in Europe that is selling some?
Sorry, I'm no help but would love to follow along with your build. Please start a build post when you get rolling. ~ Carl
Kinda of. Model A shackles are a tad (I think 1/4") bigger than Model T. Do you know what year T you have? 26/27 rear cross member is the most like a Model A, but you still need to use a '26/'27 Model T rear Spring or top pack if using a Model A rear spring. You can always shimming the extra space. I'll need to look what Zach Suhr did for my build. It's a later V8 rear with Model A shackles and a '26/27 T rear spring and cross member.
The chassis is a 26, hm don't really know if it would je wise to just make spacers to take up the play..
If you use the Model T stuff, no issue. If you use Model A spring and a Model A or V8 rear with a Model T rear cross member, you've got to do something. Plus, the '26 T rear cross member is approx. 1/4" narrower than a Model A so the spring doesn't fit either. Model T rear cross member and spring is the way to go. It looks better and sits lower than an A set-up. I wouldn't let the shackle move around with the slack back like that.
So you would put spacers between the shackle and leafspring eye? Because I would be using a model A rear axle
If using Model A shackles, I would place the "bar" next to the spring and run spacers under the nuts. I hope this makes sense. I'll try to snap a picture.
A Model T spring is 2" wide. A Model A spring is 2 1/4" wide. The Model A spring will not fit up into the T rear crossmember so you'd need to use the T spring. You can use the Model A rearend but will have to have 4 washers/spacers to space the shackle plates to make up the width difference. One would go on each side of the T spring, between the spring and shackle plates, to space the plates at 2 1/4" to match the Model A rearend perch width. Hope this helps. Lynn
Hi Lynn: Thank you. You've explained exactly what I was trying to say. The "bars" of the shackle needs to ride against the spring with no space. The 1/8" spacers would go on top of the "bars" and under the nut to make this possible. I don't know if Antique Auto in Rosemede, CA is still in business, but I thought they sold a "stepped" shackle that was 2 1/4" and 2" just for this type of situation.
Ow I am going to look it up. And other wise I will make some spacers thanks everyone for the replies. Just have to find some springs first..
Actually, I'm saying the 1/8" spacers need to go between the spring and the shackle "bars"/plates, not under the nuts. If they were put between the nuts and the shackle plates the spacers would not serve the purpose of evenly spacing the 2" T spring between the 2 1/4" spring perch width of the A rearend. Probably just semantics of how you're saying it. "Stepped" or "joggled" shackle plates, if they're available, would also do the trick to fit the two together properly. Lynn
