Projects Model a frame
Discussion in 'Traditional Hot Rods' started by 48fordnut, May 16, 2017.
  1. I have too many projects, but want to try to get this together. I have a stock model a frame that will get a z in the back next week.
    I originally wanted to do a v/8 but when I found an original good running 55 chevy eng.I thought this would be a chance to put something together a teen ager would do in the mid to late 50s.
    I have the top loader trans, f1 cross member, f1 pedals, 40 drums , backing plates, and the spindles. I also have a hurst m/m cradle for the ft. I have one of the 4 '' dropped axles like summit is selling.
    Now for the work to start.1st I have to learn how to transfer pics from my note 3 to here. That's the biggest job.
    Thanks for any input.
  2. Is the '55 engine a six? Will you squeeze it in by lengthening the frame? Or recessing the firewall?
    Got a trans adapter?
  3. It's an original 55 v/8 with the oil filter mounted on the intake. I plan to mount that on the firewall.
  4. gimpyshotrods
    gimpyshotrods
    To a restorer, that engine might be worth enough to fund building the rest of the car, with another engine, if it is not messed up.
    48fordnut likes this.
  5. Some one put a mild cam in it ,but I saw the car it came out of with mileage in the 60s, comp in the 120s ,o/p around 35.I have the original carb and starter.
    I have a trans adapter.
  6. The frame is at the welders .He is going to make a 4'' z and weld in the upper shock mt per the B/T book,Bible. Now to get busy building the trans and putting the dropped axle together.
    I don't know how to post pics,can some one give me a link.
  7. cactus1
    cactus1
    Below the reply box there is a button next to the "post reply" that says "upload a file." Hit that and choose a picture from wherever you keep your pictures. Then click the "post all images as full size." Then just "post reply" as normal.
    Tim and 48fordnut like this.
  8. cactus1
    cactus1
    So whose flathead is that??
  9. How easy is that. Thanks Cactus 1. Not what I wanted to post ,but just had to.
    cactus1 likes this.
  10. A friends, took the pic to see how the torque tube pipes looked.
    cactus1 likes this.
    Hey I'm getting it. :)
    120mm, cactus1 and Tim like this.
  12. sloppy jalopies
    sloppy jalopies
    Try a '35, '36 hollow drive shaft it tapers at both ends... one driveshaft makes a pair of headers...
    they made cool [lowd] headers when limefires were just off the drawing board...
  13. Not for me. I just wanted the picture so I could reference it later.Now to learn how to post pics from my note 3
  14. Changing out the axle for a 4'' drop, this one has the rev eye spring.
    S10_37 likes this.
  15. Take the time and box that frame. You'll be glad you did....
  16. sloppy jalopies
    sloppy jalopies
    I like to set the boxing plates in about 3/8" , that leaves a lip that can be drilled from below to add whatever you need... brake lines, tranny coolant lines, wiring etc.
  17. that's a good idea. I have read of that. I'm hoping to replicate what a youngster might have done in the mid 50s. That's when I was around hot rodding.
  18. 97
    97
    So now you are a teenager/youngster..... with some experience? :D
  19. Yikes. I guess so. Dr says I'm in good shape, but body is worn out.
