Hot Rods Model A Frame Brackets to Cut
Discussion in 'The Hokey Ass Message Board' started by MrHavard, May 24, 2018.
  1. Hey Guys, this is probably a dumb question, but I'm hoping for a little clarification. I have a '30 Model A frame that I am prepping to get blasted and boxed. I am about to cut off the fender braces, but I am unsure about the brackets ahead of them. In the picture I attached there are three brackets. I think the left and right brackets are for the cowl and hood and should remain, but what is the small center bracket? Can I get rid of it? Do I need the other two brackets? If it helps, I'm planning on building a Hi-Boy.
    Thanks!
    -John
      203.1 KB
  2. alchemy
    alchemy
    The ones that face sideways are for the old mechanical brake rods. You won't need those.
  3. Atwater Mike
    Atwater Mike
    ...unless you're using 'mec-panical' brakes, that is.
    prewarcars4me likes this.
  4. before sandblasting, i would drill out the rivets on all of them and weld nuts on the inside to make them bolt on. you will be surprised how much rust is underneath them
    patmanta and 117harv like this.
  5. bchctybob
    bchctybob
    ^^^ Good idea! ^^^
  6. Awesome tip!
  7. Thanks!
  8. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    When I removed mine, cakes of rust and crud fell out. They tend to pool moisture and collect dust, dirt, acorn shells, and pine needles from what I've seen.
  9. Dirk35
    Dirk35
    If the 30-31 Front Cowl unbolts from the cab the same way a 28-29 does, then this picture will help you. If you cut off the Hood Shelf Bracket neatly, you can probably sell them to someone that is wanting to put fenders back onto their Model A. ford.jpg
    MrHavard and patmanta like this.
