Is the power of near stock engine suficient for todays standards of driving? I'm not expecting it to be really fast, but I don't want to die in traffic eighter. Anyone know of 0-60mph time? 1/4mile time? What's the max rpm? Top speed? What's the fuel consumption? I am trying to decide is it worth messing with or not.
like 50 horse or soemthing . 1/4 mile time.. about half an hour.. i think you can get them to do 55-60
got a couple of A's...people will run over you...you have to pick the roads you run on...of course you know nobody runs the speed limit ...and if you are running 45...they come up behind you real fast...
Stock: top speed is 60 mph, Hp is 40, fuel 25mpg (+-). With a few mods: We have one that will run 85mph cruise all day @ 55-60. With the change to the rear gear, distributor, carb/intake, exhaust.
From one of the Model A sites: SPECIFICATIONS TOP SPEED 65 mph (104 km/h) 0-60 mph (0-96 KM/H) 32.0 sec ENGINE TYPE in-line four (463-484# w Trans) DISPLACEMENT201 ci (3,293 cc) TRANSMISSION3-speed manual MAXIMUM POWER 40 bhp (30 kW) @ 2,200 rpm MAXIMUM TORQUE 128 lb ft (173 Nm) @ 1,000 rpm WEIGHT2,212 lb (1,005 kg) ECONOMY18 mpg (6.4 km/l) WHEELBASE103.5 in TRACK56 in GROUND CLEARANCE9.5 in
Nothing wrong with your "A" PG. It's more realistic for a crusing speed of 50mph with a stocker and 3:78 gears. altraditional , you are going to need some mods to get a reliable 60 mph cruising speed .
