Projects Model A electric fan mounting
Discussion in 'Traditional Hot Rods' started by olds vroom, Apr 18, 2020.
  1. olds vroom
    olds vroom
    While I know it’s not traditional I run an electric fan on my model a (with a Chevy v8) just for hot hot days and bumper to bumper traffic . Most of the time I don’t need or use it. I’ve tried to use those plastic through the core mounts but they always break or rip the fins out of the radiator . I don’t run a fan shroud so I’m looking to see how some of you guys have mounted your fans. Pics would be great.
  2. Gman0046
    Gman0046
    IMG_0422.JPG Toyota Camry dual fan assembly on my 63 Chevy. Fits the stock radiator like a glove. This car connot be overheated. Those plastic mounting ties you are using are garbage.
    olscrounger likes this.
  3. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Dave Mc and Fordors like this.
  4. Almostdone
    Almostdone
    Just like Mr T body
  5. olds vroom
    olds vroom
    I don’t want to use the shroud and keep an open radiator.
  6. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    OK, here's the Spal I mounted on my '32. Couldn't find mounting brackets I liked so made these. fan2.jpg
  7. When i built my coupe i had enough room to run a traditional fan blade.
  8. olds vroom
    olds vroom
    Now that’s what I’m talking about. How does it attach in the front
  9. Almostdone
    Almostdone
    Ok I had to post a picture. One of the neat things about using that shroud, besides the fact that it’s good to use one, was it was made to fit my fan (nuts welded on). Easy.
  10. olds vroom
    olds vroom
    This is the kind of thing I’m looking for , how does it attach to the front or side?
  11. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    After making the brackets, I installed rivnuts in the radiator side brackets and used hurricane bolts to attach the brackets to the radiator.
  12. olds vroom
    olds vroom
    Please keep them coming
  13. olds vroom
    olds vroom
    There has to some more
  14. wvenfield
    wvenfield
    It's your car and it's none of my business, it's your car but why don't you want to run a shroud? They work. You might not even need a full shroud.
  15. woodiewagon46
    woodiewagon46
    from New York
    A shroud will really help in cooling, you might want to consider one!
  16. Retrorod
    Retrorod
    Hide a fan inside a shroud with the mechanical fan still in use.
    After seeing overheat problems early on (17 years on the road) my wife decided to hide a fan inside a shroud. She built one on the English wheel and riveted it together. A toggle switch under the dash allows easy access. The traditional hot rod folks don't pay any attention to it and it makes summer driving cool!
    bundybiker and olscrounger like this.
  17. olds vroom
    olds vroom
    My car has no hood and has consistently run at 180 without a shroud and I only use the fan in bad traffic conditions. I put a full shroud on my last car and all it did was overheat until I pulled it out then it ran fine. I’m really just looking for mounting bracket ideas for the fan . I’m putting in a new radiator and don’t want to mount it with those crap plastic ones that just break and rip the Fins all up,
  18. Running a sbc you can use a zips riser and center up a manual fan up 5 inches higher and eliminate the electric fan all together. HRP
    bundybiker likes this.
  19. olds vroom
    olds vroom
    Am I writing in a foreign language?im simply looking for a way to mount my electric fan without a shroud.
    nunattax likes this.
  20. Dave Mc
    Dave Mc
  21. i.rant
    i.rant
    from Illinois
    1. 1940 Ford
    It appears Mr T body gave you an excellent answer to your question.
    wvenfield likes this.
  22. Not a foreign language but it sure seems Mt T body showed you a perfect way of mounting the electric fan and I offered a alternative, excuse me for trying to help. HRP
  23. olds vroom
    olds vroom
    Yes he did I just would like to see some other ideas
  24. olds vroom
    olds vroom
    Any others?
  25. Moon50F3
    Moon50F3
    from Mesa, AZ
    Not a model a, and it’s set up as a pusher. Bent up two brackets out of some 3/16 strap, bolted the fan to them, then bolted the brackets to the radiator support. They go all the way across, so pretty sturdy. I think they’re 3/4 wide.
