I have a steering hoop for my round back spindles. Id like to reuse my Model A drag link and attach it from my F1 box to the hoop steering. Where can I get a correct ball stud to tie rod end that will allow me to do this?
The model A draglink is not long enough to connect to the aftermarket hoop steering arm. It can be done. But the steering box won't be in the neutral position.
Buy a '32 Ford ball, it will have a tapered end, with threads for a nut. None of the original drag links will be the proper length. If you go using non-stock arms, or dropped axles, or lowered springs, you will need to be able to adjust the length of the link. Use a tie rod with adjustable ends and make a new center bar. (Good luck with those threads though)
Threads are done with a tap that is termed "Popular special": 11/16" X 18 threads per inch. Mac's may have this tool, Speedway does for sure.
Well hell, where has this critical info been??? Haha. I was about to heat and move my pitman arm forward a smidge to get my steering wheel centered.
