Projects Model A direction question
Discussion in 'The Hokey Ass Message Board' started by 1oldtimer, Nov 23, 2018.
  1. I'm pretty sure I know what the answer to one question will be :rolleyes:. But I have a '28 Tudor I'm working on, it has a 2.0 Pinto motor and a T5 (now), I have some hop up parts for the motor and it fits in the frame really nice. Now I have a good friend that's going to give me his complete worn out '50 Merc Flathead.....you know where this is going right?. I'm on the fence about redoing the mounts (engine and trans), exhaust, radiator and other stuff to get the Flathead in there.
    Secondly, I have in my possession 2 different transmissions to run... one is a mechanical speedo S10 T5 and the other is a T170 RTS..........so what do you gents think...questions/comments/flaming arrows?.
    The car in question:
    https://www.jalopyjournal.com/forum/threads/automotive-a-d-d-the-28-tudor.753531/#post-10453080
  2. Rice n Beans Garage
    Rice n Beans Garage
    Dan, stay with the 4 banger !!
  3. FYI, there is a 181 cubic inch Mercrruiser Marine in my AVATAR. The '50 Merc Flathead is slightly larger than the pre 48 engine so you will have a few more bridges to cross. Check the engine out in the archives. I would pass on it and look for an earlier engine. Be sure to calculate the total costs before you start. Flatheads are expensive. I think I would leave the Pinto in there and drive the hell out of it.
    Charlie Stephens
    firstinsteele and chryslerfan55 like this.
  4. evintho
    evintho
    Yep, flatheads are expensive. I'd stick with the Pinto motor...………………...or upgrade to a 2.3 turbo. Yes I'm biased as I'm running one in my roadster. Your Pinto motor is roughly 85 hp on a good day. A 2.3 turbo produces 200hp bone stock. 300hp is easily achievable with junkyard parts! In addition, it'll bolt right in and you won't have to deal with all the fabrication nightmares. I can attest to the fact that these little motors can fly, are virtually bulletproof and can easily pull 28-30 mpg! Can you tell I'm a fan?
    Found one...……………
    https://losangeles.craigslist.org/sfv/cto/d/1987-thunderbird-turbo-coupe/6724888272.html
    Pull the motor and part out the car. There's a huge market for '87-'88 TC parts. I bought this one for $300 and parted it out for just a hair over $3000.
    Tim and scrap metal 48 like this.
  5. The37Kid
    The37Kid
    Keep the full hood closed & enjoy the Pinto. Bob
    firstinsteele likes this.
  6. I’ve been getting lucky at the pick a parts with transmissions and then the free flathead, now I’m wondering.
  7. oldsman41
    oldsman41
    For the money it will cost i would stay with the banger and play with the flatty. Tear it down and find out if the block is good most aren’t. If good than build it the way you want your money your car.
    30tudor and scrap metal 48 like this.
  8. adam401
    adam401
    Fuck all that. Pinto 4 cylinder what's going on here? When do we all of a sudden decide that the cheapest option is the best option? It would also be cheaper to yank the engine outta my bmw and put it in but in case we all forgot this is a pre 65 traditional hot rod forum. Lame econo box bullshit. Shameful.
    shivasdad and Dino 64 like this.
  9. If you have a Hot Rod you can drive and enjoy, even with a Pinto motor I say leave it alone. You want to do something with the Flat Motor, start building a second car. 5 years from now when you can finally drive the new one sell the first one to recover maybe a third of what you spent on the Flathead rebuild.
    The Wizzard
    P.S. They never go as planned and they come apart so easily.
    Dino 64 likes this.
  10. I agree with Adam, not as expressive but still in agreement. Mitch.
    clem likes this.
  11. 41rodderz
    41rodderz
    from Oregon
    My first 31 was a high boy with a 2.3 Pinto engine, automatic and 8" Mustandg rear. Great on gas and scooted the hot rod right along.
  12. Truckdoctor Andy
    Truckdoctor Andy
    Truthfully, stock to stock, I’ll bet the Pinto makes as much, if not more power. Put a small cam, four barrel, and a header on that banger and it will make more power than the flat motor. I’d keep the banger!
  13. anthony myrick
    anthony myrick
    from al
    Run the pinto like ya stole it while ya build the flatty
    This is the hamb
    Flat motors are cooler than pinto bangers (not a pinto hater)
  14. adam401
    adam401
    No doubt the pinto has more power. Just like one could take a Toyota 2jz and probably blow the doors off most of the cars on this site but that's not really what we're doing here is it.
    clem, Dino 64 and F&J like this.
  15. Stovebolt
    Stovebolt
    Dan,
    looks like the ADD may have kicked in again!!! LOL ;-)
    I will play devils advocate - you have enough on your plate atm, The Hillman, the Chevy Panel, the tudor - It may be easier, quicker, cheaper to build a bigger turbo motor for the tudor, and get many more miles and smiles out of it and enjoy the build on the other cars. To bring the tudor up into the traditional build realm will mean you will probably need to travel a long and expensive road undergoing a full rebuild, let alone the search for parts, re-conditioning them etc etc.
    Just my thoughts as another automotive ADD sufferer.
    Oh yeah - and you can send the flathead and T5 my way
  16. tb33anda3rd
    tb33anda3rd
    1. Connecticut HAMB'ers
    Pinto? Flathead?.......lose -lose.
    can't be your only options?
    Dino 64 likes this.
  17. anthony myrick
    anthony myrick
    from al
    Unless you are racing another flathead.
    Or just like the look
    Dino 64 and tb33anda3rd like this.
  18. lake_harley
    lake_harley
    1oldtimer....I feel your pain. I have a '31 Coupe that I have anguished over for more than a year.
    In my case option 1 is the Model A 4-banger (warmed up a bit) with a RTS-170 overdrive and the banjo rearend that's already converted to open drive. That, I think, would be the easy build with less fabrication since the engine mounts and spring mounts are already in place.
    Option 2 is a 2.5L S-10 engine with either T-4 or T-5 transmission. Rearend choice for this option gets complicated though depending on transmission choice and would be either the open drive banjo, early Bronco 9", a 8" Ford that would need to be narrowed about 2", or the S-10 rearend that is almost a bit too narrow. Throw in a bit of indecision between transverse leaf or coilover suspended rearend if using the S-10 engine and anything other than the banjo rearend.
    I won't even get into the issues of brakes, wheel selection and wheel bolt patterns. The hell of it is I have all of this stuff. The only big thing I'd have to do to go any direction is to build the Model A banger engine if that was the route I choose, and I've somewhat already started that process.
    If I understand your situation your sedan is actually a driver (or almost) with the Pinto engine? I think I'd go the route Charlie Steffens suggested in post number 3 and drive it. Maybe just leave the hood closed to avoid the sneers from some.
    Lynn
  19. dan31
    dan31
    When you close your eyes really ,really tight... does your dream car have a Pinto in it?.
    clem, Dino 64 and anthony myrick like this.
  20. anthony myrick
    anthony myrick
    from al
    I had a 88 ranger with a 2.0
    Worst slug I have ever owned. Even worse than the 4 cyl s10
    dan31 likes this.
  21. Rickybop
    Rickybop
    from Michigan
    "Since when...?"
    Since Ryan changed the format to include forums for traditional hot rods and customs, but also a third one...this one...to accommodate traditionally STYLED hot rods and customs. Because Ryan understands...as most here do...that some but not all can or even want to have a totally traditional car...for various reasons. So if our cars at least look traditional but have some hidden modern components, we won't be shunned, excluded, brow-beaten or otherwise disrespected. Well...except by the self-appointed traditional police posers.
    So NOT "shameful"...lol...not at all.
    1oldtimer, you've got a good lookin' Model A sedan there. The guys who suggested that you keep the Pinto drive-train obviously know how the REAL world of hot rodding is, (the real world in general for that matter...lol) and how lofty plans can stall a project. And they just don't want that to happen to you. Enjoy your car as it is. Then do a whole lot of research to decide if you really want to go more traditional...and suffer the consequenses...lol.
    One more thought. If we looked closely enough, we could pick at almost any car out there for not being 100% traditional. Of course we don't want heartbeat paint jobs and the like. But we can be reasonable.
    Good luck, 1oldtimer!
    lake_harley likes this.
  22. anthony myrick
    anthony myrick
    from al
    Cat fight
    Old school hamb
    Irish Mike likes this.
  23. a boner
    a boner
    Banger! Especially with a T-5.
  24. gimpyshotrods
    gimpyshotrods
    Blown Hemi, Hydro.
    adam401 likes this.
  25. BamaMav
    BamaMav
    from Berry, AL
    I can't believe nobody has said just put a SBC in it......
    Guess I just did.:p:D:eek::rolleyes:
    dan31 likes this.
  26. anthony myrick
    anthony myrick
    from al
    You mean a LS
    Little shevy
  27. Beanscoot
    Beanscoot
    Well at least call it by its proper name, the 122 CID, not "2 litres".
    Or 140 cubic inches, if going with that turbo one.
    It eases the pain a little.
    And I vote for the four speed.
    dan31 likes this.
  28. gimpyshotrods
    gimpyshotrods
    The smaller the displacement, the more gears it should have.
  29. Ok, now to muddy the waters more........:), it's an endearing trait I have.
    The '28 is still in project form, frame almost done and set-up for rugged duty (boxed and crossmembered) just in case. The 122 was in there when I bought it, it's now sporting a T5 and beefed up banjo. I'm trying to use a lot of stock or cast type parts, not much to re work for some motors/trans combos. Full fendered, stock Ford wires, un chopped and most likely with the hood on.
    Motors:
    The Merc motor was running but smoking on deceleration (and not overheating).
    The 122 will be rebuilt with a big valve, ported head and a cam.
    I also have a 283, 327 or 350 (all turn free but unknown condition)
    Lastly I have a 322 Nailhead in unknown condition and no adapters.
    Trans:
    A Mech speedo S-10 T5
    A T170 RTS o/d 4spd
    A 2.3 Ford T-5 w/ mech speedo mods
    All transmissions will most likely have to be rebuilt as all came from the wrecking yard.
    One's a belly button, one's expensive to build and the other 2 are slow (and expensive to build).
  30. Rusty O'Toole
    Rusty O'Toole
    Check out the flathead first. Chances are the block is cracked around the exhaust valves and elsewhere. Most of them are. If it is still good scoop it up. Then price a rebuild job. You may decide to stick with the 4 cylinder but it's nice to have a choice.
