Model A dash's
Discussion in 'The Hokey Ass Message Board' started by fandangler, Dec 16, 2009.
  1. What are you 30-31 Model A guys running for dash's other than the common 32 Ford dash. Pics?
  2. gasserjohn
    gasserjohn
    this was done in 1967...........
  3. ridin dirty
    ridin dirty
    This what im going to use in my coupe. A very early Dodge dash that I got off of evilbay. I was going to use the gas tank as a dash but it is rotted so it wasnt worth the time to fix it so this dash came along. Give me your input but not to high jack this thread.
  4. thunderbirdesq
    thunderbirdesq
    41 Ford, there's a little walkthrough of fitting it in my build thread found here...
  5. billthx138
    billthx138
  6. yblock292
    yblock292
    34 buick in my coupe
  7. yblock292
    yblock292
    40 in the 30 roadster
  8. BangerMatt
    BangerMatt
    Red oak and sheet aluminum. :rolleyes:
      86.4 KB
  9. HotRodBen1987
    HotRodBen1987
    Made one...used 59-60 chev gauge cluster
  10. I used both and I'm happy with the out come
  11. scrap metal 48
    scrap metal 48
    49 Ford in my coupe...........
  12. Stock... This instrument panel (28-29) will mount to the stock dash.
      10.5 KB
      46.3 KB
      58.6 KB
      61.7 KB
      53.7 KB
      50.2 KB
  13. 5window
    5window
    Haven't done mine yet,but it will be similar-kind of a '32 shape out of curly maple with black Faria gauges-not sure about the insert yet.
  14. dodored
    dodored
    from Concord NC
    Here is what will end up in my 31 roadster. Its a '39 ford dash - but the width fits well.
  15. Dreddybear
    Dreddybear
  16. F-1 dash in my 31 sedan
  17. mj40's
    mj40's
  18. george775
    george775
    from Nor Nev
    31 chevy
  19. modelacitizen
    modelacitizen
    I'm using this exact dash in my 30 coupe! My steering wheel is frighteningly similar to yours as well. Great minds think alike!
  20. george775
    george775
    from Nor Nev
    65 'stang column will come out for a 40 ford. instrument cluster will get engine turned insert with SW curved glass gauges. still have a long way to go...
  21. dragass
    dragass
    That's what i want to do to mine. Where did you pick up those gauges?
  22. Here's my '31 Vicky dash. The gauge panel is a reproduction accessory item called Aristocrat. It screws right over the stock cluster. I had it chromed and have an engine turned insert.
    Of course, I've enlarged the holes to accept the modern Stewart Warner gauges with the vintage Stewart Warner Speedo. The original fuel level site is top center. From left to right, ammeter, oil pressure, stock speedo, water temp, clock.
    I've spent a lot of miles staring at that cluster.
  23. Cant recall where I got them... they are Auto Meter Street Rod Arctic White Gauge Kit.
  24. Streetwerkz
    Streetwerkz
    50 Chevy dash, in my build thread
      159.5 KB
  25. 31ster
    31ster
    working at fitting a 52 F1 dash in my 31 roadster, I have to change the ends t fill in the gap.
      45.3 KB
  26. jetmek
    jetmek
    so post a pic!
  27. bustingear
    bustingear
    Were you able to do this without cutting into the stock tank???
  28. Crusty Nut
    Crusty Nut
    Unknown ebay dash with a gas pump insert with pearloid drumwrap
  29. Stock tank has been removed. Gauge cluster mounts to dash face panel.
    Merry X-Mas
