Im Looking for some pictures of what you guys have done with the dashes in Model A's with the stock tank and cowl. Im not using it as a tank but I dont want to use that "32" style roadster dash. I really like the dash in the bare metal A that So-Cal built that was in the Rodders Journal. Some sort of insert or aluminum panel to match the pattern on the tank? Any others out there? Thanks.
I did this in my 'A'. I cut the bottom from the tank,filled the centre of the dash then cut out most of the raised portion,leaving a lip to mount the stainless panel from the inside of the tank.
I cut out the bottom and filled in the indentation behind the gauge panel with flat sheetmetal. I'll cut holes for gauges later. Here's the thread with lots more pictures: http://www.jalopyjournal.com/forum/showthread.php?t=222387
