Technical Model A Dash rails
Discussion in 'The Hokey Ass Message Board' started by Jdee, Jul 2, 2018.
  1. Jdee
    Jdee
    Does anyone know how many different sizes of Model A dash Rails there were?
    Or know of a book that has that info?
    I would like to be able to ID the different ones I get in the shop.
    Thanks for any info Jdee
    I should have kept track over the years, But I oh well.o_O
  2. fiftyv8
    fiftyv8
    from CO & WA
    The process of elimination gives you at least two straight up, being one for open cars and one for closed cars including pickups.
    I also figure but don't know for sure that the 1928/29 rail will be different to the 1930/31 items.
    Where it will get tricky is for those Briggs bodies and the like which possibly had additional variations.
    It is probably a question best asked on the Ford Barn or similar.
  3. kb cookout
    kb cookout
    1928-29
    Open car
    Closed cars and trucks
    4 door sedans
    1930-31
    Open car
    Commercial cowl
    Slant window sedans , Vicky and A400
    later kb
    osage orange and Jdee like this.
  4. Corn Fed
    Corn Fed
    Actually, the 28-9 closed cars and closed PU's had different rails too.
    Dave Mc likes this.
  5. alchemy
    alchemy
    Is a 28-9 cabriolet dash rail different than a fordor?
  6. Jdee
    Jdee
    kb so are the Slant window sedans, Vicky and A400 the same do you think? Thanks for the info it helps a lot. I did have a few A400s in the shop and one guy said that his car A400 had a wider dash than the other models Vertical or horizontal I'm not sure. Thanks, Jdee
  7. kb cookout
    kb cookout
    Yes Slant window sedans, Vicky and A400 are the same if you set one along side a standard car one they have a wider center area were the center bolt goes
    I'll dig out some of the ones I have and post some pics
    later kb
    Jdee likes this.
  8. Jdee
    Jdee
    Great info Thanks. I want to build a display if I can find all the right rails.
    Jdee
  9. continentaljohn
    continentaljohn
    The 30 31 Vicky is the same width as a 32 closed car 40 5/8
    Jdee likes this.
