Model A cab mounting holes
Discussion in 'The Hokey Ass Message Board' started by mow too much, May 8, 2013.
  1. mow too much
    mow too much
    I have a question, I have an old frame that I'm using to build up new sub rails for a 29 closed cab pickup, there are no holes in the frame for the rear cab mounts, did ford only drill these holes when building a PU?
    The cab has been taken apart but luckily I have enough parts to uae as patterns, I'm going to use a boxed perimeter frame.
    Thanks
  2. V4F
    V4F
    from middle ca.
    i always was told that all the frames were the same . but i never have owned a pick up ........... good luck
  3. mow too much
    mow too much
    Steve thats what I thought, but......
  4. racur96
    racur96
    from tn
    Your right on, the pickups had the extra holes drilled when a frame had the pickup body going on it. Otherwise the rails are the same for the cars & trucks if built on the same day.
  5. mow too much
    mow too much
