Hot Rods Model A body on ‘32 chassis WITH FENDERS- Help!
Discussion in 'The Hokey Ass Message Board' started by RiffRaffRoadster, Dec 24, 2018.
  1. big duece
    big duece
    from kansas
    Looking good!
    RiffRaffRoadster likes this.
  2. RiffRaffRoadster
    RiffRaffRoadster
    Stogy-I was trying match the original style. Hard to tell on this photo, but the car had the original Chevy-orange block and intake from the ‘57 Belaire donor car. [​IMG]
    slv63, jimgoetz and Stogy like this.
  3. RiffRaffRoadster
    RiffRaffRoadster
    The intake and carb shown here were replacements done in the mid-2000’s.
    Stogy likes this.
  4. RiffRaffRoadster
    RiffRaffRoadster
    Sorry-I know very little about suspension components. I can ask Willard, the builder.
  5. RiffRaffRoadster
    RiffRaffRoadster
    Pretty sure it was part of the rear suspension ladder bar/coil over kit we got from Speedway. Is this unusual? Should it be in a fixed position with no adjustment/give?
  6. RiffRaffRoadster
    RiffRaffRoadster
    Yep-here it is...
  7. alchemy
    alchemy
    On the steering. Regular tie rod ends are best.
    Atwater Mike, raven, jimgoetz and 4 others like this.
  8. RiffRaffRoadster
    RiffRaffRoadster
    Sorry-thought you meant the rear
    Stogy likes this.
  9. greaser
    greaser
    Looking good Riff... You've come a long way!
    Stogy and RiffRaffRoadster like this.
  10. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Boy, coming along nicely. Arent you glad you didnt listen to that first shop? Now it looks like you're getting to keep a lot of the original car, and getting to do a lot of hands-on work too! Its coming out awesome, cant wait to see it back on the road.
  11. jimgoetz
    jimgoetz
    It's looking good. I like the orange motor. We used to call this color competition orange.
  12. Gasolinefed
    Gasolinefed
    from OR
    It might be a good idea to make sure the front spring is tensioned right being as how its a custom set up and the rear wasn't I might be suspect.. looks as though the shackle angle is a bit steep and the car doesn't have its full weight yet..
    brEad, loudbang and RiffRaffRoadster like this.
  13. RiffRaffRoadster
    RiffRaffRoadster
    The old SW gauges are polishing up fine-I’ll be re-using them. Remind me again what the advice is on the Sun 2-piece Tachometer? I understand the transmitter unit uses a battery that is unavailable. Can I convert this and use it?
    [​IMG][​IMG]
    brEad, slv63, loudbang and 4 others like this.
  14. big duece
    big duece
    from kansas
  15. RiffRaffRoadster
    RiffRaffRoadster
    Got it-thanks Deuce
    loudbang and Stogy like this.
  16. dan31
    dan31
    Hard to tell from the pics but does your panhard bar hit the top of the rear on compression?. and is the angle ok? , will it move your rear side to side, always heard that close to horizonial is best. Car is looking good btw.
  17. Tim
    Tim
    from Raytown Mo
    I knew you could do it ;)
  18. RiffRaffRoadster
    RiffRaffRoadster
    Good question Dan - I’ll verify with Willard tonight. We were there this weekend and jumped on the rear cross member pretty hard and it was still a good distance away. Of course the weight of the body is not on it yet.
    [​IMG][​IMG]
  19. RiffRaffRoadster
    RiffRaffRoadster
    I have a short video of the old motor starting up (it sounds awesome BTW) - any idea how to upload it here?
    loudbang, Stogy, Tim and 1 other person like this.
  20. You'll have to upload it to you tube first and then embed the link here with that little filmstrip icon.
    loudbang, Stogy and RiffRaffRoadster like this.
  21. RiffRaffRoadster
    RiffRaffRoadster
  22. RiffRaffRoadster
    RiffRaffRoadster
    Hey-it worked! Thanks Cactus
    Stogy, jimgoetz, loudbang and 2 others like this.
  23. Tim
    Tim
    from Raytown Mo
    Yeah buddy! I bet with a full car on the frame that pan hard is within spec
    Stogy, loudbang and RiffRaffRoadster like this.
  24. dan31
    dan31
    Panhard bar doesn't look as close in that last pic. If it does move your rear on compression you could always just make a bracket that bolts on the rear using the pumpkin bolts and just drop the other side a little ,it would be a little shorter but more level, not a big deal . It's really coming along now!.
  25. the oil soup
    the oil soup
    from Tucson,AZ
    I used these guys with good results. https://www.technoversions.com/TachMatchHome.html?
  26. You’re welcome. Sounds great!
  27. RiffRaffRoadster
    RiffRaffRoadster
    motor is starting to dress up nice
    catdad49, shortypu, brEad and 13 others like this.
  28. RiffRaffRoadster
    RiffRaffRoadster
    Almost everything is original to the car when we acquired it. New coil, alternator and master cylinder.[​IMG]
    catdad49, shortypu, mkebaird and 4 others like this.
  29. Tim
    Tim
    from Raytown Mo
  30. RiffRaffRoadster
    RiffRaffRoadster
    Put the body on the frame temporarily to mock up driver position for pedals and steering...
    [​IMG][​IMG][​IMG][​IMG]
    catdad49, shortypu, mkebaird and 8 others like this.
