Projects Model a banger sport coupe to 8BA
Discussion in 'The Hokey Ass Message Board' started by kevinwalshe, Feb 23, 2015.
  1. kevinwalshe
    kevinwalshe
    Moving right along. I got a 9+3 kit from Rebel Wire which looking at it now is major overkill. It does make the job a lot easier but I didn't need this amount of extra circuits since my car has no amenities in it. I'll be on the lookout for a cool looking cover for the fuse box. Let the fun begin.
  2. kevinwalshe
    kevinwalshe
    IT'S ALIVE!!!! GOT IT FIRED UP TONIGHT!!!!
  3. kevinwalshe
    kevinwalshe
    Here's another little video. Wife came home to see it run for the first time...safe to say I was quite happy!
  4. ROCKER77
    ROCKER77
    Fucking badass Kevin. It sounds great!
    kevinwalshe likes this.
  5. Binger
    Binger
    from wyoming
  6. [QUOTE="kevinwalshe, post: 11651491, member: 111797"...safe to say I was quite happy![/QUOTE]
    Congrats! No feeling like it! :D
  7. kevinwalshe
    kevinwalshe
    Gotta get this thing road-worthy and reliable for TROG. Got my lodging and ticket squared away. I cut a stock headlight bar and pulled out the oxy-acetylene to bend them. Here's what I ended up with.
    Then I threw a bit of this in it and warmed it up for yet another heat cycle to torque the head.
    kiwijeff, ROCKER77 and Dannerr like this.
  8. I've seen several cut outside the cups and weld the brackets on them, in order to keep the bar in the center - it gives strength, so the lights doesn't wobble, when driving in the dark. Dunno if it's necessary, but you might wanna test it - maybe even let another drve it, while you ride in a car in front, to see the wobble in the rear view mirror - before throwing the center bar too far away...
    I traded for a pair for mounting on the side of the frame (instead of your on-top), but has never mounted them.
  9. kevinwalshe
    kevinwalshe
    After I heated them up and they cooled completely, I stood on one to try and make it bend a little farther and they are solid. I used carriage bolts with Nylocks so they won't wiggle loose. They are quite solid, but I'll check them once I get everything adjusted for the road.
    Dannerr likes this.
  10. GASSERBOB
    GASSERBOB
    from USA
    Looks sharp Kevin. I really like it. Are you going to do your own top? Bob...............
  11. kevinwalshe
    kevinwalshe
    I might give it a go and try to make my own top. I don't own a sewing machine or any of the supplies so that will be tricky. I was thinking of using an off-white canvas with button snaps all the way around so It can pop on and off quickly.
    Dannerr likes this.
  12. ROCKER77
    ROCKER77
    Kevin I have a '30 radiator shell I will let ya use til ya get a 28-29. just let me know
    gas man and kevinwalshe like this.
  13. ROCKER77
    ROCKER77
    I will even bring it to you but I will require a ride in your hot rod
  14. kevinwalshe
    kevinwalshe
    Dannerr and ROCKER77 like this.
  15. Looking good!
  16. Just letting you know, you might want to hold on to the cut-aways, until firmly tested! :D
  17. kevinwalshe
    kevinwalshe
    Went for a little cruise this weekend with @leroux to the best bar in Long Beach. The bar would have been 5 years old when my car was built in '29.
    And another great shot with Joe's '31
    ad055, kiwijeff, Jet96 and 3 others like this.
  18. leroux
    leroux
    from SoCAl
  19. ROCKER77
    ROCKER77
    Kevin and Joe you both have bitchin coupes!
  20. kevinwalshe
    kevinwalshe
    Got a few shots taken at Cruisin for a Cure over this past weekend. Found them posted on a different site.
    kiwijeff, Dannerr, Binger and 2 others like this.
  21. kevinwalshe
    kevinwalshe
    Drove 60 miles to get fish tacos and a beer. Then drove 60 miles home. Little banger ran like a champ. Water pump has a tiny leak but other than that, perfect. This is at Neptunes Net in North Malibu.
    Dannerr, ROCKER77 and Aaron D. like this.
  22. kevinwalshe
    kevinwalshe
    Got a top made for the old girl. Zig zag sail and canvas in Seal Beach did a great job.
    Had to celebrate.
    ad055, kiwijeff, burl and 2 others like this.
  23. Aaron D.
    Aaron D.
    Top looks great!
  24. Binger
    Binger
    from wyoming
    Looks great!glad to see you putting in some miles. Cold weather is creeping in on Wyoming and my nice days are getting numbered for this year.
  25. kevinwalshe
    kevinwalshe
  26. kevinwalshe
    kevinwalshe
    Fun times on Saturday... my cam gear smoked too much meth and lost it's teeth.
  27. kevinwalshe
    kevinwalshe
    @Hitchhiker hub actually snapped off when I was removing the gear. Had to use a gear puller to get the center section off the cam. I'll get that grill on once I get this thing back together!
  28. brady1929
    brady1929
    Very cool hot rod
