Im looking at purchasing an A coupe with 10 bolt rear end that does not have an e (hand) brake. Having no experience with 10 bolts (drums) and I wont see the car until it arrives here in Japan what parts will I need to get this job done? On doing a little research prior to posting have seen these cables. Besides the lever assembly, if I go this way what else will I need? https://www.summitracing.com/parts/lok-ec8004u/ Thanks as always. Cheers Pete
You may need the internal e-brake levers and cross bars if they are missing; seems people like to leave them off.
Here is a pic of a complete 10 bolt rear drum set up. A start that may help this was from a 69 Camaro. A little crusty from sitting outside
Here is a pic of routing under car On left coming from frame is where it would go to your ebrake handle, Where the clips are near rear are going to each drum.. Hook on right to frame is like a tensioner or such to keep cable pulling even for both sides, I know different car but concept would work for you..
