on the 90' s chevy starter does any one no the part # for the bolts to bolt it to the early block the parts guy here has no idea what I am talking about thanks
I'm not familiar with these starters, but did find this. Many newer GM starters use bolts with a slightly larger 10mm shank that will be a sloppy fit if used with ⅜" bolts. This can be an issue with some remanufactured starters that have been fitted with an incorrect (newer style) nose cone with the larger 10mm holes. Or when installing a newer style PMGR (Permanent Magnet Gear Reduction) starter onto an older engine. I believe GM offers some special bolts just for this purpose. GM # 12338064 bolts have a 10mm shank combined with ⅜" threads and are 4.330" long. And GM # 14037733 have a 10mm shank with ⅜ threads and are 1.66" long. http://rmcavoy.freeshell.org/starters.html https://www.ebay.com/bhp/chevy-starter-bolts
probably because you think there is something different about an "early block". They're all 3/8" threads...but the later small starters used 10mm shank bolts. 678107 Dorman, two bucks at rockauto. Or use a GM number listed in a previous post.
thanks that was what I needed to know well the parts guy said there are no starter bolt made with metric shaft and standard threads . this is the reason that I asked here, thanks for the dorman part #
https://www.jalopyjournal.com/forum...ate-small-body-starter-on-early-block.937389/ The GM bolts are better than the Dorman
if you had told them the rear windows were closed they would have put that in search and they would have popped up
Ha ha Wednesday the guy at the commercial counter told my wife that I didn’t exist, that he needed to know the trim level of my truck and that 1 headlight for my truck was $35.00 . Then my wife gets me on the phone ,,,,, I told the guy - Why are you giving her a hard time ? Look it up by the phone number because the apostrophe throws off your computer. ,,,,,, Ohhh there’s your account. What’s the trim level,, Lt, LS,,,, I said it doesn’t matter just pick one. Your cost is $ 29.00 I said it should be about $5.00 ,,,, He says NO WAY!!!!! I told him commercial account, back shelf,,, 5.00. He says we don’t have a headlight bulb for your truck that is 5.00 I said you’re not doing so well today. First you’re giving my wife a hard time,, You said I don’t exist,, You don’t need a trim level And you don’t know anything about the commercial bulbs.... Hold on ,,,,, Comes back and says $4.78 I didn’t know you wanted one of those bulbs.
