Miller Syncrowave 250 DX with TIGRunner Welder Stock NO. 903765 $3300.00 OBO 5 – 310AMP range, Multiple Volt input 200-575 Does both TIG (GTAW) and STICK (SMAW) AC/DC welding, for use on many types of metals including steel and aluminum. Syncro Start for customized arc starts allows the operator to choose from three different starting conditions to optimize the application according to tungsten diameter and material thickness. Squarewave output with AC balance control features adjustable penetration and cleaning action while increasing arc stability on various aluminum alloys, and helps eliminate tungsten spitting and arc rectification. Dual digital meters allow for quick and easy viewing of actual and preset values of amperage and voltage. Last procedure recall automatically recalls the last procedure set-up when switching polarity. Built-in preflow/postflow provides 0.2 - 5 seconds of preflow and 0 - 50 seconds of postflow. Built-in cable hangers on both sides conveniently fold out of power supply so weld cables can be stored to prevent torch or cable damage. Built-in consumable storage located on the front panel. Includes water cooled torch, Gas Regulator,foot amperage control, ground clamp, Pulser, AC power source cord, built in Miller cooler and cart. Well maintained with very low hours, always stored inside. Just need gas to start welding Full manual here : https://www.millerwelds.com/files/owners-manuals/O359N_MIL.pdf
