Projects Mild custom '51 Pontiac Chieftain
Discussion in 'Traditional Customs' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    With a bit of a tune-up it should sound better.
    Phil
  2. PhilA
    PhilA
    Put it down on the floor and gave it a quick run down the street.
    Much better than before, nice and smooth.
    Phil
  3. Peanut 1959
    Peanut 1959
    It's amazing how quickly it fires. Sounds like the flywheel doesn't even make a full revolution before it's idling.
    loudbang and PhilA like this.
  4. Lloyd's paint & glass
    That's sweet buddy, sounds great now!
  5. PhilA
    PhilA
    Yeah, it starts really easily for the most part.
    I put the air cleaner on, set the ignition timing, idle speed and mixture.
    Had a bit of an experiment and found that a higher wattage bulb makes the alternator charge at about 400 RPM instead of having to rev the engine up to 1500+ to get it to start charging. The one in it is completely wrong.
    Onward and upward.
    Phil
  6. PhilA
    PhilA
    Got the wipers working again.
    Phil
  7. Phil, do the wipers have the dreaded acceleration slow down issue like most of the older vehicles ?
  8. v8flat44
    v8flat44
    Very nice ! Straights R GR8........good job !
  9. PhilA
    PhilA
    Yup. Uphill they stop, downhill they flap dementedly.
    Phil
  10. Johnboy34
    Johnboy34
    from Seattle,Wa
    Would a vacuum storage tank and check valve help out on the hills?
    Sent from my SM-G973U using The H.A.M.B. mobile app
  11. 51pontiac
    51pontiac
    from Alberta
    The view shown on the camera with the visor, hood ornament and waterfall is a large part of the reason why I fell in love with my 51 Pontiac way back in the seventies. Makes me wish spring were here but unfortunately we still have a few months to go (-32C last night....same as -26F).
    You are doing a great job resurrecting your car! Looking forward to more posts.
    thegreenbuzzer, PhilA and loudbang like this.
  12. PhilA
    PhilA
    Probably. I have one. It also has a booster pump.
    What will help the most will be rebuilding the wiper motor, it doesn't seal as well as it should any more. Cleaning and greasing got it working but really it needs a new seal.
    Phil
    loudbang, Johnboy34 and brEad like this.
  13. PhilA
    PhilA
    Bought some 1/8" line and fittings. Straightened out the old pressure line, fitted it to the gauge and joined everything up. Just needs a couple of P clips to hold it in place.
    Now all my gauges work!
    Phil
    quick85, 40two, Chavezk21 and 10 others like this.
  14. Johnboy34
    Johnboy34
    from Seattle,Wa
  15. PhilA
    PhilA
    Plumbed in the wipers (manifold to pump to motor to washer bottle). Wiper motor works but is tired. Washer bottle doesn't pump with the volume of airflow it's given so that needs to be investigated- given a quick daub of vacuum direct from the manifold it sprays most effectively.
    Phil
  16. PhilA
    PhilA
    I've been told I should get some green screen wash fluid and put some plastic pickles in the jar.
    Phil
    loudbang, 37hotrod, brEad and 3 others like this.
  17. Johnboy34
    Johnboy34
    from Seattle,Wa
  18. Bird man
    Bird man
    from Milwaukee
    Drive that bad boy to Tulsa this Summer for the POCI meet :cool:
    kidcampbell71, loudbang and PhilA like this.
  19. PhilA
    PhilA
    I bought some regular blue stuff at the auto parts store with that in mind, you can just about see it in the jar already!
    I'm not sure I'll have it ready for Tulsa.. not quite this year at least.
    Edit: I am still however aiming for Cruisin' The Coast in Biloxi, MS.
    Phil
  20. Ford52PU
    Ford52PU
    from PA
    love that beautiful dash!!
  21. PhilA
    PhilA
    Vacuum line complete; I'm not 100% sure the original routing but this will do me.
    Oil line goes through a gentle coil, vacuum line split into 2 with flexible vacuum hose between (needs clamps).
    Oil line still has the original spring protective cover on. Made a small clamp plate, cut two pieces of rubber pipe and put them over the lines and clamped them down.
    Hopefully that will be good enough.
    Phil
    kidcampbell71, loudbang and brEad like this.
  22. Lines
    Lines
    from Germany
    Very nice, good job
  23. PhilA
    PhilA
    Any good reason why I shouldn't use the same copper pipe for the fuel line between the pump and the carburetor?
  24. Not my choice Phil FWIW. I would use a steel line. Much stronger and harder than soft copper.
    PhilA likes this.
  25. PhilA
    PhilA
    I was thinking about that, plus the behavior of it potentially work-hardening and fracturing at one of the unions. Hence the question. I'll try find me some steel pipe then.
    Vacuum line is ok copper; if that cracks the worst that happens is my mixture goes to pot!
    Thank you
    Phil
  26. Look into that nickel copper line if you want, easy to bend pressure rated to 1500 psi, looks great, corrosion proof, used by Volvo as their oem brake line material .
  27. PhilA
    PhilA
    I've used it for brake lines in the past, it's good stuff but difficult to find around here.
    Phil
  28. David Gersic
    David Gersic
    from DeKalb, IL
  29. Napa stocks Nicop line here.
  30. PhilA
    PhilA
    Funny. Here we are fighting the difference between "lists" and "stocks". Napa said they don't have brake line any more, nor fuel pipe.
    AutoZone couldn't find anything listed for '51 Pontiac on the computer therefore it doesn't exist.
    At that point I gave up.
