Hot Rods Mig Wire .023, .025, or .035?
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Oct 13, 2019.
  1. .023
    90 vote(s)
    69.8%
  2. .025
    15 vote(s)
    11.6%
  3. .035
    24 vote(s)
    18.6%
  1. Fortunateson
    Fortunateson
    Title basically says it all except "what's your preference" for sheet metal welding...?
    Chime in guys.
    flatford39 likes this.
  2. Bugguts
    Bugguts
  3. mrharley51
    mrharley51
    use both 23 and 35...sheetmetal 23 chassis work 35
  4. LM14
    LM14
    from Iowa
    I have my 110V MIG set up with .023 for Sheetmetal work. My 220V has .030 in it for heavier welding.
    SPark
  5. squirrel
    I just keep a roll of 030 in it. Unless I remember wrong, which is highly likely. I suppose I could go look!
    osage orange, Sporty45 and lumpy 63 like this.
  6. I have a Lincoln 255, and like mrharley51, I use .023 for sheet metal and .035 for everything else.
    Bob
    Hnstray and john worden like this.
  7. anthony myrick
    anthony myrick
    Even use it with TIG sometimes
  8. I have not tried this with my TIG, although I have saved some short pieces of MIG wire for this purpose.
    Bob
    anthony myrick likes this.
  9. flatford39
    flatford39
    .023 mostly...interesting thread that I want to keep an eye on as I have some heavy chassis welding coming up.
    Another question related to this...do you change nozzle size with wire size??? Been using a half inch nozzle but am thinking of going to a 3/8 with the .023 to see the puddle better.
    Thoughts??
    Atwater Mike likes this.
  10. Budget36
    Budget36
    I have .023 in one, .030 in another and .035 in another. Prefer the .023 for sheetmetal, but have used the .030 with no issues either. Never tried the .035 though. My .030 is in my old Millermatic 35, let's off a real soft spark.
  11. I am using a 1/2 nozzle right now, but recently bought a complete Bernard cable and gun, assembly with both 1/2 and 3/8th nozzles. Seeing that I use .023 more than the .035, my intention is to give using the smaller nozzle a try.
    Bob
    Atwater Mike and flatford39 like this.
  12. OLDSMAN
    OLDSMAN
    I use .023 basically because I do so much sheet metal work. I have welded 1/4 plate with the .023 wire as well
    Montana1 and flatford39 like this.
  13. Fortunateson
    Fortunateson
    What, nobody casting a vote? You know that there are some places in this world that you are not allowed to vote on which wire size you use!
    Spoggie and razoo lew like this.
  14. carcruse
    carcruse
    x2
    Sporty45 and gasser57! like this.
  15. DDDenny
    When I bought my Miller 200 in the late 80's I had plans for structural work as well as sheetmetal so got a big roll of .030 and a small spool of .023. Started with the .030 for some 3/8" then changed it over to the smaller wire for some sheetmetal work.
    I never had welded prior so it was a bit of a learning curve, no matter what I tried the .023 wire would try to ride up between the wire and when loosened it would rat nest, man, I wasted a bunch of wire until I got creative.
    I ended up making a flap out of an old plastic number panel mounted on a pivot that lightly rested on the wire and was able to use lighter tension without rat nesting.
    Changed back to the .030 for heavier work and left it there even for lighter work, just took a period of learning what settings to use.
    X-cpe likes this.
  16. squirrel
    yeah, mine is 030
    osage orange and lumpy 63 like this.
  17. rc57
    rc57
    .030 here too
    osage orange likes this.
  18. lumpy 63
    lumpy 63
    Should probably add .030 to the ballot:D
  19. s55mercury66
    s55mercury66
    from SW Wyoming
    .030 here also.
  20. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I would keep both 023 and 030 on hand. Then switch when you need to. With 023 wire I find that you need to use an 023 liner to help keep the wire from jaming. With 030, you can use an 030 or 035 liner and tip.......most of the time 030 will do just about anything. I decided I was too lazy to switch rollers,wire,liner,and tip, so I bought a smaller (but 220) welder to just run 023.
    You can do sheetmetal with 030 but you usually have to fix some holes along the way. The 023 is much easier to use on sheetmetal.
    That said, my large welder is giving me a problem, so I grabbed the little mig with the 023 wire and dialed it up to weld on my thick tractor bucket (3/8). Did just fine......I was surprised.
    stillrunners likes this.
  21. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think the problem might have been that you didn't change the liner.
  22. JR Vig
    JR Vig
    .023 for just about everything... seems to do the trick.
  23. 1946caddy
    1946caddy
    from washington
  24. lumpy 63
    lumpy 63
    Always use the matching liners ,tips and rollers for the wire you are using.. Otherwise you are just looking to be frustrated.
  25. lumpy 63
    lumpy 63
    o_O
  26. 1946caddy
    1946caddy
    from washington
    Miller XMT 304 welder with LN25 wire box.
    Use .035 for short arc and .045 for spray.
    30A spool gun for aluminum.
    180 SD syncrowave for tig on sheetmetal, wire size according to metal thickness
  27. I run .023 in my 110v machine for the little stuff and .030 in the 220v
  28. doyoulikesleds
    doyoulikesleds
    cannt vote no 0.030, 0.045 or 0.062
  29. jvo
    jvo
    I use .030
  30. classiccarjack
    classiccarjack
