Message board settings question
Discussion in 'Questions & Suggestions' started by bill s preston esq, Oct 17, 2012.
  1. bill s preston esq
    bill s preston esq
    The HAMB shows up, for me, with wasted space on both sides of my widescreen monitor. I am on another message board and it allows me to view it in full screen by right clicking and then selecting "this frame" and then selecting "show only this frame." Then, i can save that as my bookmark so when i go back there, it is in the widescreen format.
    The HAMB doesn't have that option (at least for me). Is there another way where I can have the HAMB fill up my whole screen.
  2. Yea hit F11 on your key board or go to tools in your menue bar and select full screen on the drop down text box.
  3. What I do is go to the bottom right corner of the screen and ther'es a little space that says 100%, click on that and raise it to 125%. Fills it in and enlarges the type.
  4. chopnchaneled
    chopnchaneled
    from Buford Ga.
    If you have a roller mouse, you can press control under the shift key and
    use your roller to the size you want.
  5. Model T1
    Model T1
    Yep. On my desk computer and this ole laptop I run everything at 125%. Fills the screen and helps since I only have one good eye for now.
