Technical ***May 2020 Banger Meet Thread - 4 are Essential***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2020.
  1. luckylou
    luckylou
    from canada
  2. railcarmover
    railcarmover
    Finest crimpers made in my opinion,Thomas and Betts
    Kline makes nice strippers..shrinkable crimp fittings good,shrink tubing standard crimps better.Weatherpak or deutsch connectors for harnesses that have to come apart occaisionally,like head light..
  3. Binger
    Binger
    from wyoming
    Checking in for the Month. Not much going on. I sold my OT 61' Dodge wagon and now have a little money for banger parts! I am going to freshen up my Stock roadster mechanically. I also have some carbs out for rebuild and hopefully have a pair of 81's and a lake header on my coupe before too much longer. Hoping to have this all back together for the Dirt drags. I havent heard anything about if its canceled or not yet. Since things are opening up there is hope that this event hopefully will happen. If not I understand and I do want everyone to be safe.
    Jet96 and winduptoy like this.
  4. denis4x4
    denis4x4
    from Colorado
  5. klawockvet
    klawockvet
    I use a Snapon crimper in the states that has never failed me, but I have a better one for marine use in Alaska. I’m stuck in Utah by Covid19 so no pictures. My son has a fenwick deluxe that is better than the Snapon but it’s pretty old and probably not available.
    Jet96 and Bigcheese327 like this.
  6. V4F
    V4F
    from middle ca.
    the key to good solder is ... clean parts & controllable heat . i use rosin core , but at times i use flux compound (hard to solder) ........... the more you do it , the better you are .
  7. Gary in MN
    Gary in MN
    winduptoy and Jet96 like this.
  8. Gary in MN
    Gary in MN
    Colonial Coupe and Jet96 like this.
  9. Ron Brown
    Ron Brown
    I used to as well until I worked one summer on Diablo Canyon Nuclear plant construction. Those electricians crimped only. Figured if it was good enough for a nuclear reactor it was good enough for my car
    Jet96 likes this.
  10. Steves46
    Steves46
    from Florida
    Checking in. Will soon be installing a high compression head-hope to see a little more pepper when I hit the gas pedal.
    Jet96 and barrnone50 like this.
  11. rwrj
    rwrj
    from SW Ga
    Checking in. Had to install a windshield and wipers to be legal. It folds down, so I can still enjoy squinting.
  12. Crazydaddyo
    Crazydaddyo
    Late 31 with a small bed. Modified the stock type junction box. Not much room there.
    Sent from my SM-J337P using The H.A.M.B. mobile app
  13. We're going to run cars at VARA's abbreviated "British Extravaganza" at Button Willow Raceway (East of Bakersfield CA) in mid-this month! Peter Giddings, of course won't be there with one of his PreWar Alfa's (he passed away last year)! But in our Race Group we'll have at least 5 cars! I won't be running for position or fastest laps! I just want to test my maintenance and modifications I did over the Winter!
  14. FlyinA
    FlyinA
    Found an Bosch Model A/B magneto today, anybody ever run one of these? 9B04DA96-3D56-4D74-98CE-01E7DF94FF7A.jpeg 7438991B-5A8E-487C-9804-E7EBB1885E2D.jpeg
    Jet96, Binger, railcarmover and 2 others like this.
  15. Bigcheese327
    Bigcheese327
    I think you're right, practice is what I'm really lacking. If I just sat down once a week and spent an evening soldering together junk pieces of wire, I'd probably get handy at it. Add it to the list, I guess!
    What type of heat source do you use? I have an electric iron I bought at Radio Shack but I don't think you can adjust the heat. Or is it a matter of timing on the joint?
    I'd be up for book/video recommendations on this topic. Especially for producing what looks like something from the '20s-'40s--meaning good, professional work of that era. I find with things like this it's best to pick a system and adopt it, because a fellow can go nuts trying to consider every factor.
  16. Has anyone heard of the new Rocket 428 made by Yapp? Jumped on the waiting list for one!
  17. Jiminy
    Jiminy
    Jet96, winduptoy and barrnone50 like this.
  18. burl
    burl
    from Minnesota
    Outside looks pretty cute but combustion chamber doesn't look much better than any of the other aftermarket heads
    wonder if anybody has ever done and factual comparison in hp gains on any of these heads.
    Jet96, Retson the Racer and Binger like this.
  19. True.. Im still looking for a head
  20. winduptoy
    winduptoy
    PIRANIO'S ANTIQUE AUTOMOTIVE
    DYNO SHEET
    RUN NUMBER: 1
    DESCRIPTION: PLUG OVER CYLINDER 26 DEGREES TIMING DATE: 1/6/2013
    PHONE:
    ENGINE: SHOP STREET ROD TIME: 2:30 PM
    ENGINE NUMBER: CAAR9377 CU. IN. 213.735
    BAROMETRIC PRESSURE: 30.43 ELEVATION: 590 TEMPERATURE: 68
    STATION PRESSURE: 29.7963 CORRECTION FACTOR: 1.054786
    HUMIDITY: 65
    ENGINE TEMPERATURE: 180 FUEL: 10% ETHANOL REGULAR GAS
    GAUGE CORRECTED VOLUMETRIC
    RPM READING TORQUE HORSEPOWER HORSEPOWER EFFIECENCY
    1300 13.4 150.73 37.31 39.35 79.31662
    1500 13.6 153.39 43.81 46.21 80.71436
    1700 14 1 58.81 51.40 54.22 83.56626
    2000 14 1 58.81 60.48 63.79 83.56626
    2200 14.2 161.58 67.68 71.39 85.02209
    2500 13.7 154.73 73.65 77.69 81.42013
    2700 13.6 153.39 78.86 83.18 80.71436
    3000 13.1 146.81 83.86 88.46 77.25307
    3500 0.00 0.00 0.00 0
    4000 0.00 0.00 0.00 0
    DESCRIPTION:
    SPARK PLUGS OVER CYLINDER
    26 DEGREES TIMING
    12.5-1 AIR FUEL RATIO ALL THROUGH
    CAST IRON HEADER, SMITHYS MUFFLER
    WEBER 32-36 DGEV CARBURETOR & INTAKE MANIFOLD
    65 PRIMARY IDLE JET, 70 SECONDARY IDLE JET
    150 PRIMARY MAIN JET, 145 SECONDARY IDLE JET
    145 PRIMARY AIR CORRECTOR JET, 165 SECONDARY AIR CORRECTOR JET
    CHAMPION N11YC SPARK PLUG .032" GAP
    CRANE F-220/320-12 CAMSHAFT
    I know that this is the dyno sheet that was done on a Lion Head and the combustion chambers are similar.
    The torque peaked on this head above and correlates with the volumetric efficiency. Makes sense.
    I don't know if anyone else has any dyno sheets and how this compares to a stock set up. I'm sure that it is vastly improved. I have a Lion III (which is this dyno'd head I believe) on the Cabriolet and it runs real respectful for a flathead. My butt dyno tells me that.
  21. winduptoy
    winduptoy
    Cancelled...got the notice today
    Bummer
  22. winduptoy
    winduptoy
    Put a blower on it and use the stock head. Be different....
    Jet96 likes this.
  23. winduptoy
    winduptoy
    Well I took a whole bunch of time making the chart look like a chart, but when I posted it...all that changed
    Look at 2200 RPM, real respectful HP and Torque
    chryslerfan55, Jet96 and guitarguy like this.
  24. guitarguy
    guitarguy
    David, I use one of these. Have used it since about 1995. I had to replace it a couple of years ago because I left it in the freezing garage and it came apart. Purely my fault. It works great. It has adjustable heat and various tips, and most importantly, cord free. Useful if you do under the dash stuff as I seem to do for alot of people.I can do very tiny stuff (44 gauge), all the way up to battery cable...(although it's a little tricky to do that big if you don't know what your doing). your run of the mill 12 - 18 gauge stuff is super easy.
    https://www.weller-tools.com/professional/USA/us/Weller+Consumer/Soldering+Irons/Electronic,+Repair,+and+Everyday+-+Cordless/PSI100K
    chryslerfan55, Jet96 and Bigcheese327 like this.
  25. johnneilson
    johnneilson
    Uh.........no, do not use a stock head. Without proper quench area and the plugs located over the valves you are looking for trouble with a blower. The "B" and "C" heads have a much better combustion chamber shape but you are still sacrificing with the plug location. Just my opinion. Dennis Piranio did a nice job documenting his work, I trust it for a good reference. Retson, in all honesty it will not matter that much which head you choose. I doubt you will notice a 5 HP difference, if that much. It will depend on how well you tune the motor and the camshaft, among what, another 100 factors? Find something that you like and run it, there are parts up in your section of the state.
    Stay safe, John
  26. winduptoy
    winduptoy
    I must admit my comment was tongue in cheek. I agree that there are other considerations other than opening the JV Whitney catalogue or going to the back of the Popular Mechanics magazine and ordering a part to put on and go.
    The conversation is what imparts the knowledge and there are worse habits to have.
    chryslerfan55 and Jet96 like this.
  27. yes....may the 4orce be with you...........
  28. johnneilson
    johnneilson
    Windup, no worries, good to see you feeling frisky.
    At one time we didn't know any different and the JC Whitney was all there was.
    The Head he is asking about is basically the same chamber as the Lion IV or so. Dennis Piranio probably had some input to its design. But back to my comment, just the head alone will not make it fast, that is the hard part.
    I was up in that area last christmas and I passed on a couple Winfield heads, they are probably still there.
    Take care, remember social distancing means staying 6 feet back from the screen.
    John
    chryslerfan55, winduptoy and Jet96 like this.
  29. railcarmover
    railcarmover
    If you want a heart shaped chamber at 6 to 1 buy a Buttermore/Snyder head and use the money you save to buy a cam..or distributor or what else you need. No indictment of anyone intended but beware churched up 'new' designs in all matters,not just speed. Folks try to introduce new models to stimulate business.
    chryslerfan55 and winduptoy like this.
  30. V4F
    V4F
    from middle ca.
    i just took my lion3 speed head off . it was great for torque & hp . trying a berts 6-1 head today .
