Technical ***May 2018 Banger Meet - May Your Build Go Smoothly***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 30, 2018.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    May 12th Antique Nationals at Fontana
    May 19th The Jalopy Showdown
    Lincoln Speedway 800 Racetrack Road Abbottstown PA contact [email protected]
    June 1-3 Hot Rod Dirt Drags
    Movie Manor, Monte Vista, Colorado
    June 2-3 ECTR-LSR THE ARKANSAS 1-MILE CHALLENGE
    The event is held at the Arkansas Aeroplex (The Blytheville-Gosnell Regional Airport) at 4701 Memorial Drive in Blytheville, Arkansas.
    June 8-10 The Race of Gentlemen
    Wildwood, New Jersey
    June 20-23 MTFCI Speedster Chapter 15th Annual Tour:
    Wednesday, June 20 through Saturday, June 23.
    Grand Rapids Michigan, near Lake Michigan and the Gilmore Car Museum.
    Official Page for Registration: https://speedsterrally.com/
    Chapter Page with LOTS of pics from previous rallies: http://speedsterchapter.org/
    July 6 - 8 F.A.S.T.
    A gathering at an unnamed ranch Fri. 6th during the day.
    A "cook your Own" steak dinner at the San Luis Obispo Elks lodge Friday July 6th night..
    Santa Margarita Ranch "Trials" July 7th,
    "Early Ford" show in Atascadero Lake Park Sunday July 8th
    REGISTRATION INFORMATION:
    PLEASE CONTACT
    Phil Farber 805-544-8856 E-MAIL [email protected]
    https://www.hotforhotfours.com/documents/santamargarita2018.pdf
    September 14-16, Hot Rod Hill Climb
    Central City, Colorado
    September 28-30 ECTR-LSR THE ARKANSAS 1-MILE CHALLENGE
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $24.00 (includes S/H), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    13clicks likes this.
  2. RussTee
    RussTee
    Here talking plugs What are you guys using for plugs in your Thomas heads heat range ect?
  3. May again, El Mirage in two weeks.
    not even close to being ready.............
    Dannerr, winduptoy and Crazydaddyo like this.
  4. Crazydaddyo
    Crazydaddyo
    I have ordered pistons for my 5 main build.
    scootermcrad, Old Dawg and winduptoy like this.
  5. winduptoy
    winduptoy
    Checking in
    That's cool Crazydaddyo
    John,
    Good luck.
  6. how much CR?
    J
  7. denis4x4
    denis4x4
    from Colorado
    Been using the Zipper as a DD for the past week as my F-150 was in the shop. Will take it to a coffee run Saturday.
  8. Crazydaddyo
    Crazydaddyo
    Keeping it the same as the engine it will replace @ 9-1
  9. waxhead
    waxhead
    from West Oz
    What pistons did you order?? When will our blocks be ready??
  10. Crazydaddyo
    Crazydaddyo
    They are custom pistons from Race Tec. It is a modern style piston with a full floating pin, and total seal rings. Fingers crossed that I'll send the block for finish machine and fitting by the end of the month.
  11. Jukenut13
    Jukenut13
    Hi , I'm using NGK BP6 hs
    Dannerr likes this.
  12. fur biscuit
    fur biscuit
    DSC01412.jpg Read Mr. Eastwoods post on cowl steering design compromises. Learned that when I designed and built my last one, that it turns out I inadvertently did a good thing. By having the pivot point for the split wishbones behind the drag link and having the center of the draglink pivot point at the front hub on the center line of the axle and having the centerline of the rear pivot point for the wishbone close to the centerline of the drag link I avoided a lot of nasty issues (bump steer). I also set the akerman angle. The chassis was rock steady at 80mph and I honestly don't recall any issues with bump steer. But now I know something!...maybe.
    BigO, Dannerr, Old Dawg and 3 others like this.
  13. Very good sounding, 9:1 should allow for street driving and no exotic fuel. Which head? Eubanks?
    J
  14. V4F
    V4F
    from middle ca.
    john , why not ready . you had all winter ! lol
  15. Furb- I bet the sight of your big frame stuffed into that seat going 80 must've been amazing :D
  16. Binger
    Binger
    from wyoming
    Checking in for the month!
    winduptoy likes this.
  17. You are right, I had all winter.
    J
    Dannerr and Crazydaddyo like this.
  18. Getting prepped to go to VARA's "British Extravaganza"...Some cars to contend with are a 1950 Cad-Allard J2; a 1931 Alfa-Romeo "Monza" and a Bugatti Lagonda (what ever that is?) millermaint008-1.jpg
    Herb Kephart, Dannerr and Crazydaddyo like this.
  19. Crazydaddyo
    Crazydaddyo
    This one is going in Pop's truck, so it will get the Rutherford.
    The Eubanks head has special pop up pistons, so it will go in the next one. Maybe a shorter stroke and longer rods. We'll see when and if those blocks materialize. :rolleyes:
    Old Dawg likes this.
  20. Crazydaddyo
    Crazydaddyo
    What engine combo are you going to run?
  21. same as last year, just putting it back together Moller. The valves are a mess, probably have to make new ones.
    new driveshaft in the break stand, this one will not seperate.........J
    Herb Kephart and Crazydaddyo like this.
  22. RussTee
    RussTee
    Thanks will give them a try
  23. Checking in- with G28T engine and B gears in the chassis: IMG_2421.JPG IMG_2422.JPG
    BigO, Herb Kephart, rwrj and 6 others like this.
  24. walls
    walls
    I’m looking for a little direction on where to start.
    Engine seemed to run fine before the winter, although it was new to me(drove it around the block a couple times).
    Did a bunch of work to the car over the winter and just started it up yesterday after not being started since December.
    White/gray smoke
    Head gasket? Cracked block? Stuck valves?
    Where would you start?
  25. noboD
    noboD
    What kind of storage over winter? How long did you have it running to warm up?
  26. Take off the cap and sniff the radiator. If it smells like exhaust, you've got combustion blowing into your cooling system. If your still unsure: Leave the cap off and start the engine.. If it starts bubbling over you've got your blown head gasket, or worse a cracked block or head.
    Check the compression..(Make sure you have the throttle completely open)..If you have a low cylinder or you have a jumble of readings (over 5" to 10" or more), squirt some oil in the low cylinder(s)...If another comp. test shows the cylinder has come up; it's the rings..If it doesn't, it's the valves. If it is the rings, put some high detergent oil (like "Marvel Mystery" of ATV) in the cylinder and let it sit. Some guys will have other stuff to free up rings.
    Dannerr likes this.
  27. walls
    walls
    Stored in a garage with no heat, but had antifreeze in.
    Didn’t run too long, 5-10 mins maybe. 3 times now.
    I’ll need to pick up a compression gauge on the way home from work.
    Thanks for the suggestions, I’ll keep you posted.
  28. fur biscuit
    fur biscuit
    Monkeys and footballs. Somewhere Heyitsnate posted a great pic of it at speed on the way home from a very early billetproof. Think I have one more of it after I put the second body on.
  29. Holy Smokes, May 3rd today......
    Antique Nationals at Fontana on May 12th, just in time for Mothers Day.
    J
    Dannerr and Jiminy like this.
  30. Tired of messing with my model B fuel pump. What is the recomended 6 volt electric pump to feed dual 97's on a 8:1 compression motor.
