Technical *** MAY 2016 BANGER MEET - MAY THE 4 BANGER BE WITH YOU ***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
  2. V4F
    V4F
    from middle ca.
    your quick
  3. Bluto
    Bluto
    Been 1May here all day...............:eek:
  4. V4F
    V4F
    from middle ca.
    but , jimski your on the other side
  5. Bluto
    Bluto
    No the EU is the center of the Universe or is it Unifarce?
    winduptoy likes this.
  6. V4F
    V4F
    from middle ca.
    well I have to believe you as your there
  7. Binger
    Binger
    from wyoming
    Good morning Banger fellows. Checking in.
  8. noboD
    noboD
    good grief!
  9. That is not a compliment unless talking about his car............
  10. V4F
    V4F
    from middle ca.
    quick as in posting the banger info .
    Had some ignition problems this weekend. Got the coupe home though. I needed some refreshments to help !!
    530sandman and waxhead like this.
  12. V4F
    V4F
    from middle ca.
    shinny car
  13. Bigcheese327
    Bigcheese327
    I have a friend who is finishing up a Model A speedster with a B engine. Internally, it seems to be hotter than he realized, which makes his stock distributor seem pretty inadequate. He's looking for a good ignition upgrade for street use, but the catch is that his car is still running six volts.
    Best I could come up with was the Scalded Dog front-mount VW conversion and to run a magneto--any other suggestions that don't involve re-wiring the car for 12 volts?
  14. Bubba's Mallory conversions, FSI distributer (which is made by Mel Mallory), Old dual point Mallory, rebuild a B dizzy, WICO mag.....
    Many choices
    Hitchhiker likes this.
  15. I'd make damn sure the B distributor is at fault. From what I have heard, it should do the job.
  16. Bigcheese327
    Bigcheese327
    But are they all compatible with the 6V system? Bubba's, for instance, would be my personal first choice, but I was under the impression it's intended for 12 volts.
    I think it has a Model A distributor currently.
  17. What would the difference be? I run "modern" points and condensers in my stock A dizzy. They are from a 68 Ford which is a 12 volt car and they do just fine on 6 volts. A flamethrower coil and a Stipe distributor cam really woke my car up
  18. V4F
    V4F
    from middle ca.
    fs ignitions . electronic self advance . one of the best choices
  19. blgitn
    blgitn
    Checking in.
  20. Most points style ignitions step the voltage down to 6 Volts so as not to burn up the points.
    Sent from my SM-G900T using H.A.M.B. mobile app
    Bigcheese327 likes this.
  21. winduptoy
    winduptoy
    FYI Pertronics (FS) ignition will burn up the module if you leave the ignition on without the engine running. I do believe they come 6 and 12 Volt.
  22. then why do they use Ballast resistors to step down the voltage?
  23. B has centrifugal advance. Be a big help and look more stock if that is what he is going for.
  24. changing gears, is there a big difference in performance between a winfield updraft and the same model set up for a downdraft?
  25. V4F
    V4F
    from middle ca.
    what I have been told is that the Winfield up draft is much better than the stock set up
  26. but how does it compare to the same carb with a downdraft setup. I would assume the downdraft is better, but by a lot?
  27. V4F
    V4F
    from middle ca.
    I really don't know , but as you I would think the down draft is better
  28. WICO MAG!!!!! Once You go with a good mag,(set up right) you will never go back to anything else!!!!!
    I did try the other, but broke down within 10 miles! (Stuck on a back road!) I put the mag in and never even considered anything else! Just so you all know. (I did run a coil wire) LOL....:rolleyes: Maybe I just got a bad one?
    The Wico looks like it belongs there anyways!:D[​IMG]
    [​IMG] [​IMG]
  29. Bigcheese327
    Bigcheese327
    Turns out I was wrong, he does have a B distributor already, so we'll work with that for the time being.
    Thanks for everyone's input!
  30. You might put it on a machine and test it. I have read they tend to advance to late and not enough. I don't have any experience though, just what I've read.
    And Joe
    Every time you post a picture I like you less:D
