May 2011 Banger Meet Spring has sprung now drive'm
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, May 1, 2011.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. 1955. My first car , a 1932 Ford B (as in banger). Hapydz ! Almost 16 :)[​IMG]
  3. Bluto
    Bluto
    Looking good Hap:)
  4. -Brent-
    -Brent-
    Cool photo... definitely a neat keepsake.
  5. noboD
    noboD
    Bluto, any idea what chemical Irontite is? Maybe waterglass?
  6. BCCHOPIT
    BCCHOPIT
    Well DaddyO.... Did you get your new TOY?????
  7. Bluto
    Bluto
  8. rmak
    rmak
    from Ohio
    Let me start off the noob questioning for the month.
    I am working through the carb issues on my Model A. I'm running a Ford AAI two barrel. I actually have the car running fairly well. No more backfires and doesn't quit on idle (most of the time):confused:
    The thing I'm wondering about now is what's called the power or enricher valve in the base of the carb. Do I need such a thing for a four banger? What would happen if I just plugged it off?
  9. Crazydaddyo
    Crazydaddyo
    Received, but it is still in the crate as to not tempt me to start work on it.
    I have a couple of projects to finish before I tear into it.
  10. NORSON
    NORSON
    Picked up a B block at the corvallis swap meet this weekend. It had some repair to the deck around the 2 and 3 exhaust valves. Looks like it was repaired with bronze. I've done little cleaning to this point not wanting to make a bad situation worse. Can any of you who've been down this road give me any pointers. the block is badly rusted. - Norm
  11. Bluto
    Bluto
    What are B blocks worth? I have an extra block with insert bearings and counter-weighted crank. All in very good order. :)
  12. Had one I saw for sale locally for 400$ recently at a swap.... had babbit though. I would say well past 1000$ for what you probably have bluto.-Weeks
  13. Oh gee, thanks Weeks! I was going to offer to haul it away.
  14. that would be an expensive haul... arnt you still in europe Bluto?
    tk
  15. There are quite a few brazed or welded "B" blocks out there. You bought it. Now is the decision time. How much do you want to invest in it? Check around and see if you can get it pressure tested. The block that came with my 4 port has been repaired with braze, the intake plugs in the deck were brazed in. It has a couple of cracks repaired with braze.
    It is apparent that the 2 cracks in #4 exhaust (1 repaired) was caused by driving in the hard seat in this block. The "B" block my 2 port is on probably has a couple of lb. of braze in it or on it. That includes the 2 port. I realize that is an exaggeration but if it were gold I would scrap them out!
  16. Bluto
    Bluto
    The block has inserts..... bearings are good. Did you miss the counter weighted crankshaft part? Crankshaft looks new.
    Weeks I saw your car leaving Bako ..... What's the stumble in 2nd gear?
    Yes we are in Europe for the summer.
  17. NORSON
    NORSON
    You guys are making me feel great. I bought it as a wall hanging, if I can make something out of it I'll be one happy camper. I'll clean it up and post the pictures. Oh, did I say I bought a couple of counter weighted cranks a couple of months ago? - Norm
  18. Crazydaddyo
    Crazydaddyo
    A couple of guys from the Anti donut breakfast group and I went on a trip to Flabob Airport in Riverside this Saturday to see an antique airplane fly in and hanger open house.
    We drove @ 120 miles round trip to find that the fly in was canceled because the wind was blowing too hard. Got to see some neat planes.
  19. Jaguar6165
    Jaguar6165
    I have a question about high compression heads. I want to run the new snyders 6 to 1 head on my 28 A. I have installed a holley 94, intake and header with exhaust. To my knowledge the internals of the engine havent been touch and are all original. Would installing a high compression head be a bad idea. It seems that everyone says something different so I'm not sure. Any info or opinions would be great thanks.
  20. Stovebolt
    Stovebolt
    Dan,
    Neat photos of some great planes, and the hot rods ain't bad either;)
    Say hi to Paul for me.
  21. BCCHOPIT
    BCCHOPIT
    Just my $.02
    If the engine sounds good and doesn't smoke or push oil out the breather go for it. My engine sat for 50 years I ran it stock for 4-5 mouths it pushed a little oil out the breather I put a head on it it ran much better but pushed a little more oil out the breather. Then 3 hard years later I got another head 7 to 1 it ran real nice but my right foot and too much timing broke a piston oops my bad that engine would still be running if I timed it right :rolleyes:
  22. ebtm3
    ebtm3
    too much timing broke a piston oops my bad that engine would still be running if I timed it right :rolleyes: __________________
    Yup-- and too much timing--or not retarding the spark when pulling at low speed- will crack up the babbitt in the rods also
    Herb
  23. Bluto
    Bluto
  24. Bluto
    Bluto
    I forgot to mention. This was the block with the HAL setup on it ... with steel main caps
    I am going to fit the HAL to a five main block
    AND FOR THOSE THAT DON'T KNOW IT'S IN EUROPE
  25. BCCHOPIT
    BCCHOPIT
    What do you call this mod. to a spring?[​IMG]
    It's real hard to do a search if I don't know what it's called
    Thanks Bill
  26. "Torched" was the common term.
    Ron
  27. Bluto
    Bluto
    reversed eye
  28. Over carbed with the gutted stromberg 97 set up for go-fast mode, and a B-timing cover on my A motor makes timing difficult for this dumbass 25 year old. It really clears out at full throttle for a stocker. Buddy claimed I was going 75 mph on Porterville Hwy but I think maybe 65 is possible.-Weeks
  29. That spring as it is now will be about as effectual as no spring at all, because the second leaf has nowhere to go, and the third leaf has very little room to move. A dumb idea, IMO.
  30. Do you that eye looks reversed Jim? If you do then your eye must be better than mine. ;)
