Max overbore on a 303 Olds?
Discussion in 'The Hokey Ass Message Board' started by drag_punk, Dec 17, 2011.
  1. drag_punk
    drag_punk
    I think that covers it. I have one that I just dissassembled after years of sitting outside, block seems okay but I know it will take a fair amount to clean up the bores.
  2. 302GMC
    302GMC
    from Idaho
    Those blocks were bored 3/16" over with no problems back in the old days ...
  3. GOATROPER02
    GOATROPER02
    from OHIO
    If you ever sonic checked one you would never bore one 3/16
    .125 over or
    3.875 to 324 bore size is max
    Tony
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I was just reading an old hot rod magazine last night and there was a dragster that had a blown 371 overbored 3/16 to 406 cubes. Were the cylinders thicker on those than the old 303's?
    Don
  5. willowbilly3
    willowbilly3
    from Sturgis
    If it was a dragster they might have cemented the block.
  6. drag_punk
    drag_punk
    Cool, .125 is what I thought too, just wanted to confirm that. Thanks Tony.
  7. GOATROPER02
    GOATROPER02
    from OHIO
  8. RichFox
    RichFox
    In the time when 303s cost $25 at the junk yard. When you couldn't get a free one. We regularly went to 3 15/16. I had one. Never any problems. But your water jackets have had another 50 some years to rust. And the extra inches won't really be noticeable. Unless it's a race car.
  9. falcongeorge
    falcongeorge
    from BC
    The answer to this question is simple. Haul it down to your machinist, and have it sonic tested.
  10. drag_punk
    drag_punk
    I probably won't even go .125 but I will if I have to. I'll only bore it enough to clean up the rust. This motor was seized, I'm not after cubic inches just want it cleaned up.
  11. GOATROPER02
    GOATROPER02
    from OHIO
    Call me
    I can help you with pistons and rings...Pistons are easy in any bore size needed....The only thing we need to be careful of is ring selection(sizes and widths availablity)
    Tony
