Technical Master Brake Cylinder
Discussion in 'Traditional Customs' started by 64impala, Mar 4, 2016.
  1. 64impala
    64impala
    I'm preparing to convert my front drum brakes to disk, the back will remain drum for now.
    I've read that a "dual master cylinder" is in my best interest for safety, but technically not required.
    Question: What are a few recommended companies that make a good after-market cylinder?
    Make: Chevrolet
    Model: Impala
    Year: 1964
  2. unkledaddy
    unkledaddy
  3. Jalopy Joker
    Jalopy Joker
  4. stimpy
    stimpy
    nothing like using a factory one ( AC Delco) , available in many bore sizes and often a 1/4 the price of the aftermarket ones and 1/2 the trouble setting up the system too , as you can adapt the proven system over . and it often contains the proper combo valve with the proper settings .
    unkledaddy likes this.
  5. Roger O'Dell
    Roger O'Dell
    The GM is good I went withe the wilwood master and control valve set up , And while you're at it loose the booster and go with hydroboost, it really adds to brakeing
  6. Bandit Billy
    Bandit Billy
    ECI seems to know their stuff.
    http://www.ecihotrodbrakes.com/index.html
    My father, RIP, wasn't a mechanic but knew I was born a gear head, his best advice was "never compromise on brakes or steering"...and something to do with loose women. Made sense to me as a kid, still makes sense to me today.
  7. For a Chevy I'd select a '72-75-ish Chevelle master and matching booster if you wanted power brakes. At least you know where it came from and you can get parts anywhere.
    yruhot likes this.
  8. woodiewagon46
    woodiewagon46
    from New York
    X2 for Master Power Brakes. Any master you could ask for and loads of info. They have what you need.
  9. unkledaddy
    unkledaddy
    It's a foregone conclusion nowadays;
    CHINA, maybe Mexico or Thailand.
  10. 64impala
    64impala
    The current master cyl is located in the stock position (firewall driver side) and the current drum brake
    setup includes a stock power brake system.
    Will this dictate the dual master cyl type I need?
  11. 50 Fastback Fleetline
    from Milan, TN.
  12. Chavezk21
    Chavezk21
    The right stuff is where I got the conversion kit for my mom's 58. The parts in that kit are available at Napa. They were reasonable, and the kit was from 58-64.
  13. unkledaddy
    unkledaddy
  14. 64impala
    64impala
    Will I need to upgrade my stock "booster" when I upgrade to disk front (keeping back stock drum)?
