Projects Master blaster...
Discussion in 'Traditional Hot Rods' started by Kail, Nov 10, 2012.
  1. Kail
    Kail
    from Austin, TX
    So wouldn't the farthest forward tire trigger the light regardless or does the inside tire trigger the first light and the outside triggers the second.. I am assuming its like a door sensor at 7-11.
  2. Kail
    Kail
    from Austin, TX
    Gotcha..
  3. CGkidd
    CGkidd
    Ryan, I was just explaining how it was explained to me. Might have been for a lot older timing system who knows. One of the threads on gassers talks about it also.
  4. Ryan
    Ryan
    ADMINISTRATOR
    from Austin, TX
    Think of it this way... The lights don't trigger the timing until it sees "nothing" in it's way. If you stagger the front wheels, the lights will see "something" for a longer period of time and keep the timer from triggering. Meanwhile, you are gaining momentum and lowering ET at the expense of reaction time. Which of course can be free if you work the pedals well.
  5. fab32
    fab32
    Ryan's got it right. I can't believe the staggered front tires have to be explained in this day and age. That was all a part of "Drag Racing 101" back when I was doing it in the 60's through the early 70's.
    Frank
  6. Ryan
    Ryan
    ADMINISTRATOR
    from Austin, TX
    Staggering wasn't really all that effective until the 5-tenths "Full Tree" came about. There was an article in a late 70's or early 80's in HRM that talked about how it was really just a gimmick until the 5-tenths tree allowed enough "go time" to build momentum without losing any gain through a poor reaction time.
    Think about it. With a 4-tenths pro tree there isn't enough wiggle room there to really gain much without killing your reaction time... And since 4-tenths trees and flag starts are/were primarily used for heads up racing there really wasn't much of an advantage to be had in the 50's and 60's. So you guys were nut balls! :)
  7. biscaynes
    biscaynes
    jenkins used this trick back in the '60s.
  8. BLACKIE HARVELLE
    BLACKIE HARVELLE
    :DThat is a cool car like the wheels and i learned me something today thanks
  9. brian55lvr
    brian55lvr
    from ma
    ive not known this before---glad it was rehashed--- i love info
  10. Kail
    Kail
    from Austin, TX
    Operations at ASS are down for the holiday weekend, so that's 4 days of Master Blaster minus what I have to devote to my wife.
    Lets see what we can get done..
    All ready to cut the front end off, measured everything out, the left side is exactly 1 inch farther forward.
    Thinking I might keep the stagger unless i can figure a reason that will really effect handling.. Not going to be hitting the slalom in this beast but want to be safe.
  11. Kail
    Kail
    from Austin, TX
    Torched off the front end, left it long to see what kind of business was under the old clip job.
    Figured how far the wonky was and laid out my lines to true things up.
    Got the new frame stub mocked up ready for tomorrow.
  12. Kail
    Kail
    from Austin, TX
    One last one for the night..
  13. bobbleed
    bobbleed
    from Awesome
    Cause I'm the MASTER BLASTER drinking up the shasta, my voice sounds sweet cause it has to!
    Dont touch me cause I'm electric and if you touch me you'll get SHOCKED.
  14. TexasSpeed
    TexasSpeed
    Gonna reuse the straight axle set-up?
  15. Kail
    Kail
    from Austin, TX
    Yeah going to reuse as much as possible just clean it up make it functional. There is only a few sketchy things on this car. The original owner was pretty resourceful and I feel he did pretty good for what he had.
    It was definitely a racecar so you can see scars from its trial and errors. His welds are surprisingly good, I attribute that to the fact that he owned a trucking business and had to do a good share of heavy fab.
    I plan to add a little more "coolness" to it as it was definitely function before fashion, but in respect to that will make sure any fashion I add will be purposeful.
  16. Kail
    Kail
    from Austin, TX
    Made these gusset plates:
    Was going to make suspension mounts but could't manage to get new spring bushings on xmas weekend. Then decided that the springs (likely trailer springs) were to much of an unknown and most likely to stiff. So I plan to get new springs or have some made then make mounts accordingly.
    So till then just tacked the old ones on to make it a roller.
    So now I just have to come up with a spring rate.....
  17. sololobo
    sololobo
    Dig this build, and all of a sudden it is March 10th, what the *#*#!! Cool ass project, rock on ~sololobo~
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Great progress Kail! Looking good- can't wait to see it on the road!
    Whats luke playin with now??? :)
  19. CGkidd
    CGkidd
    Looking pretty damn cool.
  20. Dreddybear
    Dreddybear
    Luke had the Pickup and now I've got it, so Luke got hisself a real HOG.
  21. Johnny C.
    Johnny C.
    Very cool build. Can't wait to see it back on the road.
  22. Subscribed! Another wicked '55!
  23. gripelec
    gripelec
    Glad to see the car is getting a new front end, driving this thing was CRAZY!!!!!!!!! anyways, congrats :) look forward to seeing it at round up
  24. n847
    n847
    Any more progress?
  25. Kail
    Kail
    from Austin, TX
    Need to order my new springs then put the motor back in it..
    Been side tracked on a "quick" truck project I got.. but roundup is going to sneak up on me.
  26. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    Can't wait to see more!!!
  27. DYNODANNY
    DYNODANNY
    Bad ass Kail!
    Sent from my DROID device using the TJJ mobile app
  28. AHotRod
    AHotRod
    Looks like a cool project, hope your working on it!
  29. Kail
    Kail
    from Austin, TX
    Its go time!! Ordered some parts this thing needs to run by the end of the month..
    Got rid of the trailer springs
    Got it all assembled and about ready to tack
  30. Dreddybear
    Dreddybear
