Projects Martin/Larsen Ford '32 frame build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Jun 13, 2013.
  1. tmfcracing
    tmfcracing
    from Sweden
    Backside and top side with the pressed shape.
  2. tmfcracing
    tmfcracing
    from Sweden
  3. tmfcracing
    tmfcracing
    from Sweden
  4. gnichols
    gnichols
    from Tampa, FL
    Wow. Outrageous skills. My attic has a old Christmas tree and some empty suitcases. If only a frame jig and some rails would magically appear on Christmas morning! Sub'd! Gary
  5. emiliedk
    emiliedk
    from denmark
    Fantastic work guys...
    -palle
  6. Larsa2000
    Larsa2000
    from Sweden
    Working on the x-member center piece. ImageUploadedByH.A.M.B.1388414776.141948.jpg ImageUploadedByH.A.M.B.1388414804.880402.jpg ImageUploadedByH.A.M.B.1388414827.496436.jpg
  7. Amazing workmanship, thanks for sharing.
  8. banginona40
    banginona40
    Really nice !! you guys got it going on.
  9. Larsa2000
    Larsa2000
    from Sweden
    The center piece is almost done. We need to make the transmission mount on the underside, then the mockup motor and transmission can be removed. We also made motor mounts, Martin had a grate idea with the piece with the rivets which I think turned out grate.
  10. Pewsplace
    Pewsplace
    Very nice work.
  11. Larsa2000
    Larsa2000
    from Sweden
    Transmission mount under construction....
  12. tmfcracing
    tmfcracing
    from Sweden
  13. tmfcracing
    tmfcracing
    from Sweden
    The trans bracket still needs some reinforcement on the topside . The thickness is 1/4"
  14. tmfcracing
    tmfcracing
    from Sweden
    Thank you guys for your comments, glad you like this little project :)
  15. Noland
    Noland
    very,very nice work. awesome details.
  16. tobyflh
    tobyflh
    from Peru il
    Awesome work!! One question on the corner welding of the frame parts is that mig welded?
  17. tmfcracing
    tmfcracing
    from Sweden
    No, everything is done by the Tig ,even the weld on post #51.
  18. doctorZ
    doctorZ
    beautiful work!! i love the rear notch. super clean.
  19. 340HilbornDuster
    340HilbornDuster
    Awesome Work Guys!!! Maybe one day I'll be this good...practice, practice
    Å Schysst Lada! Wish my Garage looked like that!
    Aloha Tommy
  20. cheesegrater
    cheesegrater
    from california
    Been fabricating since 69 & going to shows since before that & this chassis is the NICEST one that I have ever seen although Im a little biased towards the dimple die work as several years ago I built the "Cheesegrater" a fully louvered 32 hiboy roadster with LOTS of dimple dieing lots of uniqueness on this one thats for sure keep the pics coming please
  21. Not much more that can be said about how killer your skills are on the build.....As it all has been posted....I like the crossmember set up you built......Very nice design and workmanship.
    Sure wish I could tig like that....
  22. Larsa2000
    Larsa2000
    from Sweden
    Almost out of the jig.....
    The arms from the rear axle to the leaf spring needs to be fabricated, and some adjustments to the front beam has to be done.
    ImageUploadedByH.A.M.B.1390864959.752549.jpg ImageUploadedByH.A.M.B.1390864999.068348.jpg
  23. tmfcracing
    tmfcracing
    from Sweden
    Today we make them Rear Leaf Brackets .
  24. Larsa2000
    Larsa2000
    from Sweden
  25. Larsa2000
    Larsa2000
    from Sweden
    Out of the jig and the front axel in place. Will redo the rear panhard and rear shocks needs to be squeezed in. Then on to the body...
    ImageUploadedByH.A.M.B.1393283272.356628.jpg ImageUploadedByH.A.M.B.1393283287.601773.jpg
  26. L. Eckart
    L. Eckart
    Your fab skills and designs are great. As others have commented, one of the nicest 32 frames on the HAMB. Looking forward to seeing the rest of the build. Thanks for posting.
  27. Atwater Mike
    Atwater Mike
    I have a 'portable' frame jig also...(it's on 4 casters that have 'feet' alongside, so I can level it anywhere solidly on my perfectly level floor!)
    I also have a C-5 airplane inner cargo door that's 7/8" thick, honeycombed aluminum. I use it on top of the jig when no frame is on there, a nice big assembly table.
    The '32 frame you're doing is a work of art. I strongly approve of your radius-welding method.
  28. Larry Pearsall
    Larry Pearsall
    I just found this today, Now that your all most finished with this chassis , I'd like the same thing only with Ford Motor and Tranny mounts , I'll even give you more time than this one took if you need it,, Great detail and work......
  29. Tomlu
    Tomlu
    from Sweden
  30. Pewsplace
    Pewsplace
    Nice work! Keep the photos coming.
