Projects Martin Ford '32 Roadster build.
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Feb 19, 2016.
  1. hasty
    hasty
    Very nice. Is that for more travel or to lower the car as well?
    Looking forward to see the full front set-up.
    Amazing workmanship as usual.
    Please keep the updates coming!
  2. tmfcracing
    tmfcracing
    from Sweden
    Below is the fab of a member with a bolted lower section supporting rear torsion bars , exhaust system and with a driveshaft ring.
    The removable bottom is just for exhaust and driveshaft access.
    saltflats, rod1 and loudbang like this.
  3. tmfcracing
    tmfcracing
    from Sweden
    Just to get the idea
    saltflats, rod1, 54reno and 1 other person like this.
  4. tmfcracing
    tmfcracing
    from Sweden
  5. tmfcracing
    tmfcracing
    from Sweden
    Thanks Hasty , I'm glad you appreciate my fabs :)
    As you says , want the car 3-4 inches lower then my 5w and also get a great travel .
  6. Tanoki
    Tanoki
    tmfcracing likes this.
  7. loudbang
    That is some mighty fine work you do.
  8. 1-SHOT
    1-SHOT
    I like where this is going . What are the spring rates on the bars you are using? Thanks Frank
  9. brigrat
    brigrat
    from Wa.St.
    Speechless.........................................................
  10. rod1
    rod1
    Thanks Martin,I needed a charge.Now about those flight tickets..What date?
  11. tmfcracing
    tmfcracing
    from Sweden
    They're 1.050's and depending on arm length I be around 380-450. Thinking of making the length adjustable.
  12. tmfcracing
    tmfcracing
    from Sweden
    Summertime works for me ;)
  13. tmfcracing
    tmfcracing
    from Sweden
    Hese an older picture when I were about to make the motor mouths. I use 2 plates bolted upfront on the block and they rest on top of the frame rails . Makes it easy to center the engine and adjust hight adding blocks between rails and plates.
    ls1yj, rcnut223 and loudbang like this.
  14. tmfcracing
    tmfcracing
    from Sweden
    A time ago I started the time consuming of cleaning up the block. After lots of grinding I realized how messy the garage turned out so I wait for a warmer day to keep grinding outside.
    Tim_with_a_T and loudbang like this.
  15. Mart
    Mart
    Excellent fab skills.
  16. loudbang
    Sure, wouldn't want a GARAGE to get dirty :eek:
  17. tmfcracing
    tmfcracing
    from Sweden
    I know it's geeky :) I just ike it as clean as possible . Grinding cold rolled or heat rolled is ok but cast steel is really something else .
  18. tmfcracing
    tmfcracing
    from Sweden
    Working forward with the support for the rear torsion bars . This is for the backend of the bars . There will also be a 45 degree support from the top of the kick-up later on as there's going too be some major loads on the bar tubes .
    Tjompen, Rich B., rod1 and 4 others like this.
  19. 54reno
    54reno
    You sir are an artist, love it, beautiful.
  20. loudbang
    Dam they look so nice like they were "store bought" or something.
    brady1929 likes this.
  21. ls1yj
    ls1yj
    from Kentucky
    Tmfcracing,
    Can you share your technique for getting your welds to looks so smooth? Like where you welded boxing plates in frame?
  22. harpo1313
    harpo1313
    from wareham,ma
    Unbelievable workmanship right there !!
  23. Pewsplace
    Pewsplace
    Perfection in process!
  24. AmishMike
    AmishMike
    This is sculpture - beautiful art work. Would love to see all blown apart to admire every piece. Wish I could do ear as nic work.
  25. hasty
    hasty
    Any progress on this wonderful project?
    Tjompen likes this.
