Projects Martin Ford´32 5 Window Build
Discussion in 'The Hokey Ass Message Board' started by tmfcracing, Aug 29, 2011.
  1. tmfcracing
    tmfcracing
    from Sweden
    Think it could be neat to have a removable Trailer Hitch on the car in case I want to bring the bike or my brothers '67 Aquacraft someday.
    Started with some cutting,bending,welding and grinding to make this thing that is placed in the middle of the rear crossmember.
  2. tmfcracing
    tmfcracing
    from Sweden
    And the removable Hitch.
  3. tmfcracing
    tmfcracing
    from Sweden
    Next up was to draw a x-member that fits under the gas-tank.
  4. tmfcracing
    tmfcracing
    from Sweden
    And here it is.
    kiwijeff likes this.
  5. tmfcracing
    tmfcracing
    from Sweden
    And welded on the frame.
    brEad and kiwijeff like this.
  6. Toast
    Toast
    from Jenks, OK
    Wow! Nice work.
  7. fab32
    fab32
    Nice progress and looking like your doing a "quality" build as shown by the obvious skills and equipment you have. Keep the pictures coming on any further effort you put into this one.
    Frank
  8. tmfcracing
    tmfcracing
    from Sweden
    The exhaust system consist of realy well made stainless casted mainifolds and mufflers from Speedway motors, the tubing is 2,5" stainless from my metalsupplier and flanges is made by myself. Still has the last tubing behind the rearend to do and some ours of tigwelding to .
    The center cross tube gives a more even flow for the fumes and also make the hole system more stable when both sides are bolted together.
    Am a little bit worried that those muffler dont restrict the sound enoth, I dont like cars that sounds more then what they can performe.
    Anyone that have some experiance with those mufflers ???
  9. tmfcracing
    tmfcracing
    from Sweden
  10. tmfcracing
    tmfcracing
    from Sweden
  11. tmfcracing
    tmfcracing
    from Sweden
  12. tmfcracing
    tmfcracing
    from Sweden
  13. brady1929
    brady1929
    you are a true craftsman
  14. Graffiti32
    Graffiti32
    from Illinois
    Ya!!!!!:D
  15. tmfcracing
    tmfcracing
    from Sweden
    Anyone that have used a electric in-tank fuelpump in a 32 tank ? Please let me know wich one to use and how to set things up. =)
    I think there will be a carb on the car to start with but at the same time I would like to mount returnline to the tank and a electric pump with regulator so its already done for a later e.f.i.
  16. Deuce Roadster
    Deuce Roadster
    This is a outstanding build.
    It is even more impressive when you factor in that you are in Sweden. Parts must cost considerably more and then add freight. :(
    On the 32 Ford roadster that my friend and I are doing ...we used a GM pickup electric fuel pump. It is a in the tank type. It was for a mid 90's V6 and only put out 7 or 8 LBS of pressure. No Photos as off yet but I will get some and the NAPA part number for the pump. We got a regulator and a fuel pressure gauge for it also.
    You can see the post on his 32 roadster build here
    http://www.jalopyjournal.com/forum/showthread.php?t=552777
    Sadly, progress has been slowed down recently.
    Life, the HEAT and other factors have delayed the build.
    Planning on getting back at it ... more seriously in a few weeks.
  17. tmfcracing
    tmfcracing
    from Sweden
    Thank you guys for all the positive feedback, makes it even more fun going to the shop. :)
    Deuce Roadster- thanks for your input, my plan next after im done with the exhaust system is to make the brake/gas lines before I disamble the chassis for paint.
  18. tmfcracing
    tmfcracing
    from Sweden
    Did the last parts on the exhaust yesterday evening, now it is just a pair of hangers in the back and some welding to do.
  19. tmfcracing
    tmfcracing
    from Sweden
  20. Rem
    Rem
    Nice fabrication and details. Thanks for the updates.
  21. Nice work on the exhaust, clean. I love it!
  22. billylo
    billylo
    Man that trailer hitch is the coolest.......I would love to have a twin built for my 3 window. Awesome work!!!
  23. tmfcracing
    tmfcracing
    from Sweden
    I can mail you some dxf drawings on it if you like, bring them to your local water/laser cutter and you are on the way.
    The H-beam part will fit your frame but the other things needs to be made to fit your rear x-member and the actual hitch that you buy. :)
  24. kiwicowboy
    kiwicowboy
    from linwood nc
    great work and a nother 32 is a live
  25. Awesome fab work....thanks.
    M
  26. nailhead terry
    nailhead terry
    Send us a dxf and me and Billy lo will both have one ha ha !!
  27. I'd love a copy of the dxf as well - is it small enough to e-mail?
    Steve
  28. tmfcracing
    tmfcracing
    from Sweden
    It only takes 36 kb =).
    Dont know how to add the file thru HAMB´s "send email" so if you guys really want it you can send me a pm with your email adress.
    You can´t get it before next week because I´m heading for Santa Pod UK today and wont be back until monday.
    Wrooooom:D
  29. tmfcracing
    tmfcracing
    from Sweden
    For the body I started to cut out the old floor , it was channeled.
    Also the few parts left from the original subframe and the sheet below the decklid (actualy this car had tree of them =)
    Here is a friend helping me out =)
  30. slepe67
    slepe67
    dude, get your passport in order and come take a vacation in northwest florida this winter. And if you get bored, you can stop by and help me with my project!
    Looks great, keep it up!
