Technical *** MARCH 2016 BANGER MEET - MORE DAYLIGHT TO WORK ON BANGERS! ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2016.
  1. bangerbob
    bangerbob
  2. A BONED
    A BONED
    Hi V4F, I've checked timing, it's set at 5 degrees advanced at idle. I've also checked points gap, 0.016'.
  3. V4F
    V4F
    from middle ca.
    do you know what it is running @ speed ? not knowing your motor , 35* total should run 50mph or so
  4. A BONED
    A BONED
    I got the old cast iron bodied Mallory flat cap dizzy rebuilt by Bubba's Hot Rod Shop in the US. I believe full advance comes in at 1800rpm with a total of 30 degrees...
  5. V4F
    V4F
    from middle ca.
    ok , will it rev up in neutral ? or just wont pull the load ? ...........
    can you get 35* total out of the dist. ?
  6. A BONED
    A BONED
    It seems to rev up fine in neutral, under load is a different story.
    I might get the dizzy spun up on a machine, you think that I need a total of 35 degrees?
  7. V4F
    V4F
    from middle ca.
    not being there : it doesn't take much retard to kill the top end . I would try 35* just cause you haven't . it wont hurt anything & will eliminate one area . fuel flow next . ... steve
  8. A BONED
    A BONED
    Thanks Steve, will do.
  9. Bluto
    Bluto
  10. V4F
    V4F
    from middle ca.
    jimski , good to hear from you . interesting parts/tools there .
  11. Bluto
    Bluto
    I have been very lucky to find the tools I've collected over many years. Somethings are rare enough that if no one tells you "These things once existed" some might pass by them at a swap meet. Often old tools are best to solve old problems. Many companies went out of business and people have just forgotten.
  12. V4F
    V4F
    from middle ca.
    we are to old for most of the REAL parts/tools company's . we just out lived them !
  13. hey, can you run a 4 blade model B fan on an A water pump? Running an A head and would rather use the B fan I have than buy an A fan.
  14. Yes
    Sent from my SM-G900T using H.A.M.B. mobile app
  15. rtsidejohnny
    rtsidejohnny
    Hey folks, I'm looking for the model A flywheel lightning demensions. I did go to the link at the beginning of the thread, but it's no longer there. I also tried the search function but still no go.
    Thanks very much!
    Johnny
  16. 29 Speedster
    29 Speedster
    from Colorado
  17. Wardog
    Wardog
    I can't seem to get many of the links to work.
  18. colinsmithson
    colinsmithson
    Guys just be a little carefull using more than 30° with standard oiling systems can be a little hard on bearings
  19. V4F
    V4F
    from middle ca.
    trying to figure out his problem . not recommending all the time .................
  20. Jiminy
    Jiminy
    Which links are you referring to?
  21. colinsmithson
    colinsmithson
    He has 30° total at 1800 rpm that should be enough for plenty of rpm but like you said it should be checked
  22. Wardog
    Wardog
    image.jpeg I was curious to see if this was setting timing with vacume or if it was tuning carbs or something else but can't open it.
  23. trailerpark
    trailerpark
  24. Jiminy
    Jiminy
  25. Jiminy
    Jiminy
  26. rtsidejohnny
    rtsidejohnny
  27. Wardog
    Wardog
    Thanks for the new link Jiminy.
  28. trailerpark
    trailerpark
    It's I that owes you Johnny, your write up on the Hot Rod Hillclimb inspired me to get a RPU and we are registered for the hill climb this year.
  29. Liberty Garage
    Liberty Garage
    Darn! I have an extra one all done steve
  30. 4bangerbob
    4bangerbob
    trailer park
    thanks for the drawing, I had been looking for it via the link however as discovered the link is not working.
    I thought I would take the dimensions, plus measure us some A and B flywheels I have and make a complete drawing and see how the calculated weight (solidworks feature) come out.
    I used the dimension suggested in the drawing applied to a Model B crank, and calculated weight came out to 40.87 pounds. Then applied what weight reductions I could for the V8 clutch style to a model B and came out with 35.18 pounds.
    The I thought I would just see what it would take to get the stock Model B down to about 30 pounds. Unsure if this would be a usable wheel? Safe? Thoughts?
    If some dimensions are off or missing, let me know and I will changes and add.
    Cheers.
    mdimages, 5280A2 and MJW like this.
