you can solder and silver solder with it , it aint cheap compared to large tanks but it has its place dave
They can be as handy as a shirt pocket, and agreed, great for silver solder. Fair warning, the tanks don't last long so have 1/2 again as much as you think you'd use...
I have a set I’ve used it for heating up seized parts Soldering etc. The oxygen goes quick It’s handy for sure But don’t expect big tank performance
I considered one of these before I bit the bullet and bought a "full size" oxygen/acetylene welder (henrob type torch). These small torches would have been expensive to buy gas for and the torch kit costs quite a bit so to me it didn't make sense. But since you got the kit for free and just need to get the gas, you have a very different situation - not sure what the gas tanks cost in your area but you should be able to have that up and running for the cost of a couple of pizzas. I believe they can heat a relatively small area to fairly high heat, unlike regular fuel-air torches (propane or MAP and air) that have a cooler and bigger flame, heating slower and spreading the heat over bigger areas. Sometimes you want to heat a large area, sometimes you just need to heat a small spot, different torches work for different situations. Assuming you don't have a real O/A torch I'd say you should get it up and running, and try it out. You can't have too many tools, and sometimes you really need the focused heat of a oxygen/fuel flame.
m 2 cents you light the torch an the oxygen is gone , get a set of hobby torches or a trades set on a cart if you want to get any use out of it i never had any luck with the set i tried
That little oxy cylinder is good for about 10 minutes of use once the valve is opened. It makes the map gas work at a higher temp, but not for very long. Might be OK if you need quick higher heat then straight map gas can give you, but it gets pretty costly pretty quickly. If you want to play with a torch, buy the real thing with the bigger cylinders. These small cylinders won't last long enough to learn anything. Gene
