Technical Manual transmissions
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 18, 2019.
  1. Dino 64
    Dino 64
    from Virginia
    lothiandon1940 and Desoto291Hemi like this.
  2. Desoto291Hemi
    Desoto291Hemi
    Dino,
    Good looking combo,,,,is that a crate 350?
    Looks ready to run.
    Tommy
  3. RmK57
    RmK57
    Probably a Jerico Dr4 or Liberty. Not the most street friendly but who cares.
  4. mkebaird
    mkebaird
    Hot rods have three pedals! Love my Muncie behind the SBC!
    Torkwrench likes this.
  5. Dino 64
    Dino 64
    from Virginia
    Yup, Mustang z T5 with a tail shaft from Modern Drivetrain made in USA and puts the shifter forward, instead of a used tail shaft from a S-10. Hoping the hydraulic clutch won’t leak. Now mounted in the chassis
  6. Desoto291Hemi
    Desoto291Hemi
    Should run really well,,,I like the valve covers and intake manifold,,also headers.
    The frame looks really good as well,,,good work.
    As a matter of fact it all looks fantastic,,,good work indeed!
    Tommy
    lothiandon1940 and Dino 64 like this.
  7. Nothing fancy here just plain ol ford 3 speeds in both of them. 34 coupe & 34 roadster
  8. Dino 64
    Dino 64
    from Virginia
    Thanks Tommy, appreciate the kind words :)
    lothiandon1940 likes this.
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Good choice! I know we are supposed to do vintage stuff on the HAMB, but these transmissions make virtually any engine street able. They handle HP and torque and give your engine the chance to operate at an rpm your ears can stand on the xway.
    I always felt that transmission choice was the single most important choice a builder makes.
    To me, when you have a manual transmission it feels like YOU are driving the car, when you have an automatic.....you are along for the ride.
  10. Nova Thug
    Nova Thug
    from SG Vizzle
    V8, F body, T5 for the Nova.
    833 in the Barracuda.
    NV3500 in my late model DD pickup.
  11. WB69
    WB69
    1950 F1 with factory 3 speed and 324 Olds Rocket, 1929 Model A with toploader 4 speed and 351 Cleveland CJ, 1932 5 window 39 3 speed on the floor with 59AB and 1932 5 window factory 3 speed with flathead F. Guess it's manuals for me right now anyway.
  12. Gotgas
    Gotgas
    from DFW USA
    Out with the pushbutton Torqueflite, in with the Tremec TKO. :)
    Stock '57 392 Hemi, Wilcap flywheel and adapter, early Tremec 5-speed, 4.10 geared 8.8.
    Torkwrench and lothiandon1940 like this.
  13. wrenchbender
    wrenchbender
    Ok so every car I’ve built in the last 25 years has had a stick trans in it even my dragster has a 3 speed toploader from a 57 ford pickup you know the one with a 1 3/8” input shaft it’s indestructible lol so now I build this new Afx car and by the way the original car I cloned had a pushbutton torqueflite I had a couple coworkers finally break me down and convince me this car needed a torqueflite so I stepped up bought all the good parts had to use a later style one cause I couldn’t find a useable cable shift pushbutton one and it’s the biggest pain in the arse I’ve had the thing in and out of the car 6 times for various reasons and mostly it’s been torque converter issues so I’m doin away with that piece of crap and putting a clutch in it like i should have in the first place however I’m gonna do something I’ve always wanted and still run the torqueflite but with a b&m adapter and a scattershield I should have the best of both worlds and if it’s a colossal failure I have a nice 833 patiently waiting it turn lol
    Torkwrench and Desoto291Hemi like this.
  14. Torkwrench
    Torkwrench
    Everything that I own has a stick shift. My 55, 57, 59, and 34 Chevys all have M-20 Muncies. My 59 GMC has a Saginaw 4 speed. Just bought a H.D. Muncie 3 speed for my 56 Bel Air Junior Stock drag car project.
    My 55 Cameo that I'm finally finishing will be a stick. It'll get a Muncie 4 speed, unless I can find another H.D. Muncie 3 speed. For towing, I'd rather have the lower 1st gear of the H.D. Muncie 3 speed.
    Even my daily driver, O.T. 1984 S-10 is now a stick shift. It was a V6 automatic truck when I bought it, and I swapped in the T-5 from my old S-10.
  15. Steve Ray
    Steve Ray
    I have literally never owned a car with an automatic.
    mkebaird likes this.
  16. RusTnut
    RusTnut
    from Mn-AZ
    How did you keep the column shifter with the T5 5 speed bolted in?
  17. Elcohaulic
    Elcohaulic
    My next car will be a three on the tree. I would love to get a 55 to 64 GM with a V-8 and a tree on the tree. There's just something about them, the way they seem to grab and hug the road once the clutch is let out.
    My cousin had a 61 Olds 88 with a 394 and a three on the tree, two door hard top in a nice blue, he painted the stock wheels gloss black and put chrome lug nuts on it along with duals with can glass packs. Wow was that a nice car!! It was one of those cars that just stays in your mind, nothing special but yet..
    Desoto291Hemi likes this.
  18. Frames
    Frames
    37 Packard behind a 308 Hudson Hornet engine. I made the adapter. Close ratio, compact and quite beefy. 1 1/8" x 10 input splines. Same as Chevy. 2nd picture from Wil-Cap site. A ford pick up aluminum trans called a 3 speed plus 4th overdrive. I have one. It is going to be used in my full race p1010185_0001_001_0049.jpg CADDILAC TO 4 SPEED FORD TRANS.jpg 6 carb Cadillac powered 32 roadster
